Old 11-12-2011, 06:11 AM
ghodge's Avatar
Member #20378
Bighorn Issue on 2011 850 Touring
I bought 26x11x14 (rear) Maxxis Bighorns for my 2011 850 Graphite Touring LE model. I immediately had a problem. A bracket that juts just into the inside fender space is rubbing / gouging a groove into the inside lug on the tire. Only rubs when I accelerate and when the shock compresses. Has anyone experienced this? Would wheel spacers resolve the issue. It is rubbing between 1 and 2 inches into the tire. What size spacer would be recommended? If I space that out it looks like I could cause some rubbing on the front of the rear fender when it compresses the shock.
Old 11-12-2011, 08:00 AM
Wheelie Man's Avatar
Member #15100
Just turn the shock up 2 or 3 clicks to give it more room..
Old 11-12-2011, 09:46 AM
Old 11-12-2011, 05:57 PM
bobx2's Avatar
Member #14376
There has been a bunch of info about this. Check out this thread. Turning up your preload adjustment on your shocks will not fix the problem.
XP Touring owners watch your tire sizes with stock wheels.
Old 11-13-2011, 05:27 AM
Member #15100
I see that they rub on the foot well. Yes Turning up your preload adjustment on your shocks will not fix the problem for that.
Old 11-13-2011, 02:39 PM
ghodge's Avatar
Member #20378
Thanks to all. I am thinking about a combination of spacers and maybe grinding that corner on the foot brace. Looks like I need about an inch and a half clearance. I don't want it to get into the inner wall of the tire so it has to clear.
Old 11-14-2011, 02:38 PM
ghodge's Avatar
Member #20378
As I went back and looked again at the thread suggested by bobx2. I realized on page 3 fishy did the cut back of the footrest brace and this did not completely solve the problem. Especially since I usually ride 2 up it may even be more of a problem for me. Anyone try to add rear wheel spacers as well as cutting back the brace to complete the fix?
Old 11-15-2011, 02:09 AM
Canonball's Avatar
Member #10473
Hi,
I have a 2011 850 Touring LE with 26-9-14 front and 26-11-14 rear wheels.
The rim is a original Polaris 14"SIXr.
No need for spacers or modifications.
No rubbing with 1 or 2 passengers.
No rubbing on trails.
Ingo
Old 11-15-2011, 06:06 AM
ghodge's Avatar
Member #20378
Interesting. First are your tires Maxxis Bighorns? And all you did was replace the rim with the OEM SIXr? Did this shift the inside of the tire out so that it doesn't infringe on the passenger footrest? I like to get airborne and will come down hard. Has your configuration passed a similar test. This sounds like a better solution than all of the possible adjustments. I have been looking at cutting back the footrest bracket, stiffening up the shocks, potentially spacers, and lift kits. Some combination of effort till it gets fixed or I guess a new set of tires to replace the ones that have 2 hours on them.
Old 11-15-2011, 06:35 AM
Canonball's Avatar
Member #10473
Hi,
yes, standard Bighorn (no BigHorn 2.0)
Size is 26-9-14 and 26-1-14. I saw the rims and liked it. Before I mounted them on a 500er Sportsman. After switching to a 850er Touring I mounted them instead of the original Carlisle 489. The shift the inside a lit bit out (see it at Sportsman XP850 Touring Limited Edition). If you click picture #2 at 150% you can see the footrest.
What do you mean with test?
I was in the italien mountains last month and on a trail in the Ardennen - no problem.
Ingo
1 inch wheel spacers for polaris sportsman touring
26x11x14 bighorn 2011 polaris 850 touring
best tires for 850 polaris touring
big horn polaris images
picture polaris 850 touring big horn
polaris 2878030
polaris 850 touring atv with 26 inch maxxis big horns
polaris sportsman 26 bighorn
polaris sportsman 850 touring big horn
polaris touring 2011 wheels
polaris wheel spacer 1 vs 2
tires for polaris 850 touring
2008 Touring 800 vs 2011 Touring 500 krzgoat ATV Purchasing and Price 9 11-05-2011 08:25 PM
Anybody w/2011 850 Touring? Teak ATV General Discussion 3 10-13-2011 05:48 AM
2011 550 Touring -- Fuel Tank Issue biz4two Polaris XP 4 09-05-2011 05:10 AM
Sportsman 500 Touring H.O... Seat locking issue? Dalmus Polaris Sportsman 6 04-27-2011 05:35 AM
Polaris Touring 850 issue (520194 = drossel stuck) Redsox ATV Repair and Maintenance 3 10-19-2010 10:59 AM
