11-20-2011, 11:31 AM
Member #19733
wheel spacers??
does anyone have suggestions on 1.5" wheel spacers? I have been doing some looking round on ebay and i have found a few options. Some are one piece aluminum that bolt right on and others are aluminum but you have to press out the stock lugs and replace them with longer ones. I guess my question is which are stronger,safer? They are all about $73.99 a pair so price not an issue..
 '09 sportsman 500 H.O
front and rear double tube bumpers
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
nerf bars w/full footwell skid plates
14" polaris wrec rims w/ 26" sedona rip saws
11-20-2011, 02:04 PM
Member #5629
Pm sent
Con
11-20-2011, 04:15 PM
For what its worth, You should NOT need to install longer studs for the spacers AND the spacers I have seen come with LONG studs installed....
11-21-2011, 11:26 AM
Member #20378
I just bought a set for my 2011 Touring to resolve rubbing issues. I got them from SuperATV.com. Cost $90 with tax and shipping. They are solid aluminum and look really good. Easy to install.
2011 850 Touring Graphite LE
Maxxis Bighorns, 1.5 " spacers
TCP Boot Guards
Polaris front & rear bumpers
Rotopax 4 Gallon & Mounting plate
Garmin eTrex and RAM Handlebar Mount
Direction2 Fender Flares
11-22-2011, 10:38 AM
Member #20531
PAIR 1.5" Wheel Spacers Polaris Sportsman 800 2009-2011 | eBay
Hands down the best Spaces I have found. We have bought some 30 sets from this guy. He is the only one that makes em so the studs cannot strip out and spin in the Aluminum Spacer. He machines a 5 sided area that the Stud presses into, the stud has 5 sides to it so it cannot every spin out like others we have ran into. Check em out.
11-22-2011, 03:17 PM
Member #19733
spacers
thanx .. that was what i thought.. nice to hear it from someone who has actual experience with them..u made up my mind
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
11-23-2011, 12:12 AM
Member #16947
I have been running spacers for years.. Those listed above from Ebay in my opinion I would NOT run.. Just due to the fact there isn't really enough surface area matted up against the rim (causing more stress on bolts/rims). If you look around at some other companies you will notice that they are a full piece of aluminum giving more contact area. Just giving ya my .02
2006 Sportsman 500 EFI
-28" Outlaws, Rad relocate, QSC kit, snorkeled, ODI grips, 4 speaker stereo.
2005 Yamaha Grizzly 686 BBK & Mudbuster cam
-28" Outlaws, Rad relocated, Snorkels, Exhaust snorkel, fan over ride switch, clutch kit
2009 Polaris RZR LE--27" Mudzillas, snorkels
11-23-2011, 06:54 AM
Member #20378
Here is what I got from SuperATV.
TCP Boot Guards
11-23-2011, 12:04 PM
Member #19733
hey u purchased a set for $ 90.. was that a pair or all four?
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
11-23-2011, 12:13 PM
Member #19733
hey ghodge.. icant really tell from the picture.. and i have seen it on e bay.. if it is a bolt on.. or do i have to press out the oem studs and replace 'em.. sorry for being repetative but for that much money i just want to be sure.. thanx!!!!!!
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
2011 850 polaris wheel spacers, are wheel spacers on a sportsman 850 strong, bolt on tire extenders for atvs, dual tire spacer for an atv, graphite or aluminum wheel spacers for atv, polaris 850 do i need a wheel spacer with a 2 lift, polaris 850 wheel spacers, polaris front wheels spacers, polaris sportsman wheel spacers, polaris wheel spacer texas, running wheel spacers on all fours polaris, wheel spacer polaris xp 850 touring 2011
