Old 11-27-2011, 04:58 PM
pruav's Avatar
Member #20385
spacers will i need them
It is time for new tires. The stock front are getting worn down. Stock tires size is Front(26x8 12r) and rear (26x11 12r). I want to get Bighorn 2.0 in 26x9 12r and 26x11 12r.
I know I might need the spacers on the front, but will i need spacers on the rear?
Would it be better to go with the 25x8 12r and 25x10 12r. I know the bighorns run bigger than stated.
2007 Sportsman 500 "Lil Mule"
Old 12-20-2011, 04:15 PM
Corbettchild's Avatar
Member #19435
Old 12-23-2011, 07:43 PM
Graysen's Avatar
Member #21437
I had 25x9 (front) 25x 11 (back) and I went to Mudwolfs 26x10 (front) 26x12 (back) and my front right tire was rubbing the tie rod ends so i needed 1" spacers for front
1999 Polaris Sportsman 500 Remington Special Edition
26" MudWolf's
2" lift kit
UNI filter
1" spacer (front only)
2500lb winch
Old 12-23-2011, 07:58 PM
Member #19435
Welcome to the forum! Were your spacers expensive & what kind are they?
Old 12-23-2011, 08:18 PM
Graysen's Avatar
Member #21437
Thanks. My spacers were $140cdn after tax, they are made by Billet I believe i bought them from Royal here is the link
2011 Spring/Fall
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 12-23-2011, 08:19 PM
Graysen's Avatar
Member #21437
fail link didnt work pg 151 lol sorry
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 12-23-2011, 08:37 PM
Graysen's Avatar
Member #21437
But ya i like them little more then i would have liked to spend but very easy to install and durable took my bike out today and beat the crap out of it but im never going mudding in winter again bend my rad guard pretty bad and the ice cut my CV boot and I blew my CV joint lesson learned ill post link as soon as I put the vids up on youtube hope I helped
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 12-23-2011, 08:52 PM
Member #19435
Thinking of upgrading to 26" bighorns or 25" still shopping around. I have 25x8x12 & 25x11x12 on now stock.
Old 12-23-2011, 08:55 PM
Member #19435
Sounds like you had fun though!
Old 12-23-2011, 09:20 PM
Graysen's Avatar
Member #21437
Hell ya I had fun so worth it! before i bought my tires i did some research around the net and i found out that you can go 1" bigger and be able to leave rest stock but apparently my ATV was not that case it may also be because i wrote it off my smoking a tree little over a year ago (being a dumb ass) and needed to replace the whole front end 3 grand later (not worth it) but looks like your ATV is pretty new from your pic so you should not have any problems but if you do go bigger you need to make sure the inner tire is not rubbing on anything like for example the tie rod ends like mine but if that is the case just get a spacer's but i did read a bit about your tires hitting your fenders after going bigger and i know a guy that drilled new holes on his floor boards then moved the floor boards back about 1-1.5" which moved the fender back. My ATV when the front suspension is squatted it rubs the fender (which is not a big deal) and my front bumper (which worries me) waiting on a response for that fix on another thread.
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
do my atv need a spacer
front end spacers polaris sportsman
polaris 25x8-12 tires do i need wheel spacers for 25x10-12
will i need spacers??? solid_crimson ATV Wheels & Tires 21 03-23-2011 04:59 AM
spacers smkngstv ATV Wheels & Tires 2 03-07-2011 01:18 PM
Need Spacers? Breakineven ATV Wheels & Tires 2 12-26-2010 04:22 PM
help with spring spacers-please help mmdstech ATV General Discussion 6 11-26-2010 05:03 AM
wheel spacers and 27`s 800 P-word ATV Wheels & Tires 4 07-17-2010 06:28 AM
