Old 12-04-2011, 08:58 PM
hvtexskeeter's Avatar
Member #18309
Installing new wheels on 2004.5 sportsman 500ho
I recently bought a set of new factory take-off alluminum wheels and tires off of a 2012 Sportsman 850xp orange madness edition to put on my old 2004.5 sportsman 500ho. The bolt pattern is the same but the hubs on my 2004.5 sportsman will not allow the new wheels to sit flush on the hub due to the 4 humps that are cast into the hub. I know I will have to put on longer studs on the hubs do to the thicker alluminum wheel but has anyone every ground off the humps to except a different wheel? Does not look like it will weaken the hub just dont want to have to widden while wheel base with wheel spacers (or spend the $$$$). See the pic below.
Old 12-05-2011, 08:48 PM
thomaseweber's Avatar
Member #2655
Don't look like it would bother anything.
Sent from my PC36100 using Tapatalk
Hey Ya'll watch this- if i say this i'm getting Stuck.
2004 Ford F350 Lariat 4x4 6.0 Litre FX4
2004 Ford Ranger 4.0ltr 4x4 5spd
2009 Polaris sportsman 850xp
Old 12-06-2011, 04:14 AM
Member #1958
I've never noticed that hump before...or its never been an issue for me. From your picks it looks like your studs are chewed up pretty good anyway. You can get extended studs fairly cheap. I'd check on them before you grind and you might should check the difference in offset of your wheels vs. the xp wheels to make sure there are no clearance problems.
Old 12-06-2011, 12:32 PM
Member #18309
polman do you know where I can buy extended studs (3/8 24)? I checked Orielys auto parts close to my house and they said that they didnt have it listed by size just by vehicle and they didnt have atv's. I would have to bring in one of the studs and go thru all of thier stock to see if I could find a match.
Old 12-06-2011, 05:33 PM
Member #18309
Took another look at the wheel and tire swap and noticed that my itp 589's are slightly rubbing my front tie rod ends just a bit. Guess I need to add wheel spacers anyway. Really dont want to go grinding on the stock hubs to remove the humps either. The only problem now is that the rear of my sporty measures 48" with the 12'wide 589's and the front is 46". The offset on the XP alluminum rims is in fact different as measured today they are about 3/4 inch deeper from the back of the rim to the mouting surface of the hub versus the stock steel rims. So my best guess is the 1 1/2 inch spacers will really only move the tire about 3/4 of an inch out. That and the 489ATII that will be running on the XP rims are alot narrower than the ITP 589's. The only reason that I care about width is that some of the trails that I ride on in New Mexico have a 50" maximum width rule. I plan on running the 489 / XP rims in New Mexico so hopefully it will all work out. I looked at the 1 1/2" wheel spacers on ebay. PAIR 1.5" Wheel Spacers Polaris Sportsman 500 1996-2008 | eBay anyone have any other recommendations? Thanks in advance.
Old 12-07-2011, 05:05 PM
Member #1958
Just search ebay for "polaris extended studs"
Old 01-02-2012, 08:25 AM
JKOLKA's Avatar
Member #21872
Did you get them installed. What did it take to make them fit. I have same issue.
Old 01-02-2012, 09:26 PM
Member #18309
I bought the wheel spacers off of ebay listed above and they were machined to fit around the 4 humps on the polaris hubs and fit perfectly. Only problem is the short studs on the stock polaris hubs will have to be replaced with longer studs so that I can get have proper thread engagement thru the nuts with the thicker wheel spacers. As it is now with the spacers the threads do not even stick thru the nuts. I have always wanted at least 2 threads showing on a bolt as general rule. Still need to find where I can buy longer studs that will fit a polaris hub and havent had really luck searching ebay etc..... If anybody has a supplier let me know. PS the 850XP wheels fit good with the spacers with plenty of clearance / no rubbing and do not stick out past the fenders.
Old 01-02-2012, 10:23 PM
POLARIS13's Avatar
Member #20347
I tried getting the xp aluminum wheels to fit but they would touch my shocks and something else I believe....they are designed for the xps wheel set up....and for the lug....DON'T TRY orileys, napa, or any place....I did and I even looked in there parts book and the smallest one they sell is 7/16.....mine were siezed up and I snapped one off one time so I looke at the above places.....the best place is the dealer. My dealer had a tub full of them for a buck a piece! Pretty cheap for a POLARIS BOLT/WHEELE STUD. Any questions, ask!
Old 01-03-2012, 02:30 AM
JKOLKA's Avatar
Member #21872
Please update when you do.
04 sportsman stud size
2004 polaris sportsman 500 wheel spacers
2004 polaris sportsman 500 wheel studs
2004.5 polaris sportsman 500 wheel spacing
2004.5p0laice
2008 polaris sportsman 500ho bolt pattern
2009 polaris sportsman 500 ho rim widths
2012 sportsman 500 wheels xp
aftermarket wheels stock tires 4x4 polaris sportsman 500
aluminum wheels for 2004 polaris
bolt pattern for 2012 sportsman 500 ho
bolt pattern spacing fpr 2004 polaris 500 sportsma
front rim size on polaris sportsman 500 2004
hd2 wheel polaris sportsman 500 ho
need rims 02 polaris 500
newer wheels 2004 sportsman forum
polaria wheel spacer picture
polaris wheels longer studs
what does wheel spacers do
what size tires go on a 2004 polaris 500
2004 500HO Sportsman idling issues Muddrman Polaris Sportsman 1 10-06-2011 01:52 PM
2002 sportsman 500ho tires and wheels psa692 ATV New Members 1 03-06-2011 08:32 AM
New Fuel Sender for late 2004 Sportsman 500HO resqu51@msn.com ATV Performance Modifications 0 01-02-2011 06:02 PM
2004 Sportsman 500ho front axle bunker471 Polaris Sportsman 3 01-26-2010 03:08 PM
2004 sportsman 500ho electric start kwejs ATV Repair and Maintenance 7 01-06-2010 01:03 AM
