Old 12-10-2011, 06:51 AM
DethStroke's Avatar
Member #19896
Question 28" Radial outlaw on 2011 850 XP ?
Hello guy´s
I have a question.
Can I mount the 28 Radial Outlaw on my 850 Xp without a Liftkit, or can I get problems than ?
Mfg DethStroke
Old 12-11-2011, 07:24 PM
wishiwasfishin's Avatar
Member #14854
I ran them on my 2011 550 without any problems. I put on my lift because I wanted more ground clearance.
2011 Sportsman 550
14" High Lifter XL2 wheels
28" Outlaw Radials
3500# Viper Max winch
3" High Lifter Signature lift
2009 Honda Rancher AT
14" ITP wheels
26" zillas
2003 Rancher ES
14" ITP wheels
26" Mud Trax Tires
3000# Gorilla winch
High Lifter lift springs
Old 12-12-2011, 06:14 AM
DethStroke's Avatar
Member #19896
Thank you for your information have you some pics for me to show ?
Old 12-12-2011, 02:56 PM
chevyguy317's Avatar
Member #21313
I have 30" Mud Lites XXL on my 11 850XP. My suspention is set to its stiffest position but i only have a minor rub when i get a little air.
Old 12-12-2011, 06:24 PM
Member #14854
with out lift.
with lift.
2011 Sportsman 550
28" Outlaw Radials
14" ITP wheels
26" zillas
2003 Rancher ES
14" ITP wheels
26" Mud Trax Tires
3000# Gorilla winch
Old 12-13-2011, 07:08 AM
lost cause's Avatar
Member #9763
I have seen 30's run on the 550/850 with no lift. So yes, 28's will fit with no lift. But it does look so much better with the lift.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 12-13-2011, 10:19 AM
DethStroke's Avatar
Member #19896
Thank´s that looks very good!
The problem is, that i ride my Xp on legal roads
And I a think a lift kit is not made for road riding , or ?
Old 12-13-2011, 02:44 PM
lost cause's Avatar
Member #9763
The lift kit will raise your center of gravity a little but you probably won't even notice. You can counter that with the offset wheels and/or wheel spacers which will widen your stance and make you feel more comfortable if you plan on making quick, highspeed turns.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 12-14-2011, 07:23 PM
Member #14854
As you can see, you dont need a lift to run the 28's. I only did the lift because I wanted more clearance. I also did aftermarket wheels to get a wider and more stable stance.
2011 Sportsman 550
28" Outlaw Radials
14" ITP wheels
26" zillas
2003 Rancher ES
14" ITP wheels
26" Mud Trax Tires
3000# Gorilla winch
Old 12-14-2011, 09:04 PM
ZEUS's Avatar
Member #7484
You dont want more offset in your ATV. Will make more kick in sides. Thats one of the best attractive of the 850XP.
Polaris Sportsman 850 XP Camo 2010 - The Best
Honda Rancher 420 4x4 AT ES 2009 - The best MPG !!
28 outlaw radial atv tires
28 outlaw radials
28 radial outlaws
28 tires 2011 polaris 850 xp
30 outlaw radial sportsman
custom offset atv 850 polaris
highlifter polaris ranger xp 28 outlaw radials
lifted sportsman 850 xp with 28s
outlaw 2 atv tires
polaris 850 xp with 28 inch outlaws
polaris ranger 28 tires
polaris ranger on 28 outlaw
polaris sportsmab 550 with 30 inch outlaw radials
polaris sportsman 28 inch radial
polaris sportsman 850 with 28 mudlites
radial outlaw
radial outlaw atv tires
what size radial outlaws for polaris 850 xp
xp 850 with 28 radial laws
2011 Outlaw 90 10SuperCab Polaris Outlaw 5 12-24-2011 10:03 AM
29.5" Outlaw 2 on Sportsman 850 UnityH8r ATV General Discussion 0 09-14-2011 07:57 PM
2011 Outlaw 90 Prddave 2011 2 04-27-2011 02:16 AM
outlaw radial? zillas? on a 500 h.o.? polaris5ho ATV Wheels & Tires 7 04-11-2011 01:49 PM
Input on the Radial SWAMPLITE REPTILE 27"... apltx08 ATV Wheels & Tires 15 11-27-2010 05:54 PM
