The executioners pull better in the mud/snow in my opinion. They also seem to last a little better than the swamplites. The swamplites are lighter weight though and they do ride a little better. The other thing is that the executioners seemed to run a little smaller than their stated size while the swamplites were true to their size. If you spend more time on the trail, and at higher speeds, you may want to go with the swamplite out of those two, but if you spend more time in the mud, you may want the executioner.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
