12-13-2011, 02:55 PM
Member #21120
Tire pressures
Hi All,
New to the site. I have a question. I just installed a new set of Maxxis Bighorns on my 2010 850 XP. How much air pressure are you all that run these tires using? The decal for the OEM tires call for 7 psi front and 5 psi rear. Is this the correct pressure for the Bighorns as well? Thanks
12-13-2011, 03:22 PM
12-13-2011, 03:29 PM
Member #21120
 thanks
12-14-2011, 07:07 AM
Member #14376
I ran 5 psi in all four. If you ride at speed in rocky areas then I would suggest 7 psi in front to protect your sidewalls and rims. 14" rims kind of suck if you are in to hard riding. Very easy to pinch the sidewall at lower pressures. Never had any problem with the rears.
12-15-2011, 08:25 PM
Member #20716
I have two XP Tourings with Bighorns. I run 7 lbs in the desert rocks all around. Rides like a cloud and handles well. The Touring sticker calls for 7 front and rear.
Saguaro6
Gilbert, Arizona
2012 850HO XP Touring
2012 550 XP Touring
His' n and her'n
12-20-2011, 02:50 PM
Member #19435
12-21-2011, 02:06 PM
Member #21120
Thanks guys! Been away last few days.
2010 850 XP EPS Sunset Red.
Polaris Heated Grips & Thumb.
Rear Rack Extension.
Deluxe Front & Rear Brush Guards.
Glacier 60" Snow Blade.
3500# Super Winch with Synthectic.
Highlifter Front & Rear Springs.
Maxxis Big Horns.
Polaris Front Lock & Ride Box.
LED Road Lights.
UNI Air Filter>
2012 polaris atv tire pressure, how many pounds of air pressure should be in my polaris sportsman 850 tires, how much air does my polaris atv tires need, how much air in polaris tire, how much air in stock rim with 27 tires on 850 polaris, how much air is in your tires polaris 850, how much psi in bighorn atv tires, how much psi on polaris fourwheeler tires, how much tire pressre in polaris atv, how much tire pressure goes in a 2011 polaris 850, maxxis bighorn air pressure, optimal tire pressure for polaris 850 atv, polaris 850 atv tire pressure, polaris 850 correct tire pressure, polaris atv tire pressure, polaris tire pressure, proper tire pressure 850 touring, psi for atv tires polaris, tire pressure atv polaris recommened, tire pressure on polaris sportsman 850
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
What is the best tire for a 2wd ATV?
jlaudio_sport |
ATV Wheels & Tires |
5 |
10-13-2011 01:36 PM |
Tire fit?
Skold |
14 |
12-16-2010 12:54 AM |
Tire ??
cwlongshot |
6 |
09-27-2010 05:56 PM |
what tire
johnnyjaws |
0 |
09-16-2010 06:38 PM |
tire help
huntingtheworld |
1 |
08-11-2010 03:52 PM |
