12-15-2011, 04:34 PM
Member #21379
aluminum wheels, any drawbacks?
i just picked up two used sportsmans, one came with ITP SS aluminum wheels and the other has steel wheels with bald tires. i'm planning on getting the same wheels for the other one. i was wondering if there are any cons with aluminum wheels besides the price?
i know in general aluminum doesn't bend, it cracks. i dont think i need to worry about cracking them..
12-15-2011, 07:32 PM
Member #14854
I cant think of any cons. They weigh less and dont rust. Enough positives that I dont look for any cons.
2011 Sportsman 550
14" High Lifter XL2 wheels
28" Outlaw Radials
3500# Viper Max winch
3" High Lifter Signature lift
2009 Honda Rancher AT
14" ITP wheels
26" zillas
2003 Rancher ES
14" ITP wheels
26" Mud Trax Tires
3000# Gorilla winch
High Lifter lift springs
12-16-2011, 06:59 AM
Member #9763
No cons for aluminum wheels.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
12-22-2011, 09:12 AM
Member #21379
thanks. waiting for them to come in. pics to follow
12-22-2011, 09:36 AM
Member #18006
MxSuperFly25: Don't forget to check your wheel studs though. I picked up a set of Polaris Alloy wheels with the stock tires on them. They were new. Someone had decided to change wheels and tires on their new ride and was just dumping the stock set. I put the "new" wheels and tires on the '07. Even with the tapered lug nuts, I couldn't get a very good grip on the wheel studs. I later found that when switching to alluminum or alloy rims you need longer wheel studs. Changing them wasn't too hard and I think I got all 16 new studs for $30. But I had already crossthreaded all the lug nuts trying to get them to grab the shorter studs. I was lucky enough not to have to buy new lug nuts. I was able to clean up the messed up threads with a tap and die set.
So just a quick word of experience. If you make this change, check to see if you need longer wheel studs. It may save you a headache down the road. I shudder to think about the miles I put on my machine with only barely there cross threaded lugs holding the tires on.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
12-24-2011, 06:40 AM
Member #21243
keep a eye on the wheel nuts they like to come loose on aluminum wheels.
12-24-2011, 09:41 AM
Member #21379
will do, thanks for the advice! i have two 01 500HO's and the one has ITP SS wheels with the ITP lugs, and they worked out fine. I ordered the same exact wheel/lugs for the second one so i should be good, but I will double check just in case.
12-24-2011, 04:33 PM
Member #19986
Just my 2¢ worth but one drawback with aluminum wheels is the corrosion factor affecting the air tight seal. Particularly around the valve stem. This has been an on going issue with the alloy wheels on my trucks. Steel wheels do not seem to have the "blossoming" corrosion problems associated with aluminum / magnesium counter parts.
Aluminum is one third the weight but the softer density causes it to scratch, dent and bend more easily and that is why aluminum wheels are thicker at all points and need the longer studs.
The unsprung weight of alloy wheels has inertial effects which have both advantages and disadvantages depending on the situation; much like an aluminum vs steel flywheel.
2006 Sportsman 800 EFI - purchased 10-2011
12-24-2011, 06:38 PM
Member #19703
well i only know of two (2) drawbacks on alum wheels...
for one, when cornering, (because of alum oxidizing with air) can cause that the tire (rubber part ) to come loose,after this happens you might get sand on the inside.
IF this happens there will be afew pieces of sand/rock anything really between the tire and the wheel which will cause it to leak air... SLOWLY but it will make the tire go flat... had it happen to me while having a 3-4 hour ride..... the tire was fine... stopped for a break... 30-40 mins later... the tire is flat... and inflating it helps temporarily...
the other minus is they scratch....the rim looks ugly after ward...oh and i dont worry about breaking them... never broke a wheel...
hope i helped.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
12-25-2011, 02:45 PM
Member #21055
If your wheels aren't broke why fix them? cool looking wheels are just that. I would rather spend $ on other ugrades. I live in a rust belt, steel rust alloy corrode just as bad.
2009 honda rancher stock aluminum wheels and tires, atv highlifter steel wheels, atv steel rims or aliminum, clean corrosion polaris rims, cons of aluminum wheels, do aluminum atv wheels bend easily, highlifter aluminum or steel rims, how easily do aluminu rims bend, how easy do itp rims bend, polaris 14 rims causing flats, polaris aluminum wheels cleanup, polaris aluminum wheels used, polaris extended wheel studs, polaris sportsman extended wheel studs 800 x2, polaris wheel studs, remove tires from polaris aluminum atv rim, sportsman 550 steel wheel, steel vs aluminum atv rim, used itp rims polaris, what are the with that atv of aluminum rims come in
