12-18-2011, 03:42 PM
Member #20347
Should my front tires bow-out!?
i have a 2009 sportsman 800 EFI HO and the bottom of the front tires are out further than the top.....it looks like this
There are no ajusters to line them up.
WHAT ARE YOUR THOUGHTS!??
12-18-2011, 03:47 PM
Member #16865
I'd check your wheel bearings. Jack it up and see if there's play in the wheel. I've had wheel bearings do exactly what you're describing.
12-18-2011, 03:54 PM
Member #15110
Mine is like that too, and I have a 2008 Sportsman 500 EFI, dealer said it was fine.
-Rocko
2008 Polaris Sportsman 500 EFI
Boardwalk Blue
2500 Warn Winch w/ Synthetic Rope
Front and Rear Brush Guards
Rear Rack Extender
Glacier II 52" Plow
2009 Yamaha TTR-230 Dirt Bike
(Since Polaris doesn't make dirt bikes!)
12-18-2011, 03:58 PM
Member #13071
with my flat track quad slammed on the ground my fronts only tip in about 3/4 of an inch and when i say slammed on the ground i mean 2 1/2 inches of ground clearance with me on it.
12-18-2011, 04:13 PM
Member #11247
Before wheel bearings, worn out springs are the most common cause. Especially if you use a plow or have a lot of miles on it.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
12-18-2011, 04:31 PM
Member #20347
okay....ill check the wheel bearings. it has always been this way....so i think it should be fine!
12-19-2011, 05:40 AM
Member #14376
That is called negative camber. That is how they are made and that is the normal look. Nothing to worry about unless something feels loose.
12-20-2011, 03:55 AM
Member #17740
mine does the same thing and i have a 2006. I think its suppose to be like this since it is used for uneven ground and turning.
12-20-2011, 05:27 AM
Member #19332
Mine does the same. When you accelerate hard and the weight comes off the front wheels they will look like that. Press down on the front of the vehicle. If they stay the same, you may have a problem. If not, it's just the alignment geometry.
2011 Sportsman XP 850 EPS
Nicknamed "KATT" (Kickass All Terrain Toy)
Polaris Lock & Ride Front Storage Box
Polaris Lock & Ride Rear Storage Box
Polaris Deluxe Front Brush Guard
Polaris Deluxe Rear Brush Guard
Polaris Handle Bar Guards
Polaris Lock & Ride Back Rest
Polaris 3500lb Winch Kit
Polaris Winch Accessory Kit
Polaris Wireless Winch Remote
Polaris Trailerable ATV Cover
Polaris Hand Warmers
Polaris Thumb Warmer
GoPro HD Helmet Hero Camera
"I fire up the willing engine,
Responding with a roar.
Tires spitting gravel,
I commit my weekly crime..."
06 polaris sportsman 500 tires bow in, 2006 polaris sportsman tires bow in, 2008 polaris sportsman 500 4x4 efi drive train, are my wheels suppose to bow in in 4x4?, can atv tires bow, do atv tires bow, front tire looks bowed out, front wheel bows out, front wheels bow out on bottom, is it normal for my front wheels on my atv to bow in, rear tires bowing in, tire bow out, tires bow out on front of car, what do bowed tires look like, what makes tires bow out, whats the ground clearance of a polaris predator with 18 tires, wheels bowed out, why are my car tires bowed out, why do my atv tires bow in on the top, why does front wheels bow out
