12-20-2011, 05:32 PM
Member #7365
Another wheel and tire package question..
Hi guys
I'm new to the board and just recently purchased a Sportsman 800 EFI from my local dealer and have been eye balling some new wheels and tires ever since I picked up the machine. I've finally decided that I want 27inch Swamp lites and 14inch STI C7 machine wheels.
Interco Swamp-Lite Kit
Now my question is can I fit 27s with the new wheels without modification to my bike as in having to use wheel spacers or will the new wheels take care of the offset? Also would I need to worry about getting a clutch kit to run this size tire? Thanks in advance! -Eddie
(anyone want to buy some OEM wheels and tires? haha  )
2011 Polaris 800 EFI Green/Black
(That's because there's no room in the front part, it is taken up by a super high tech three wheel drive system that senses which tire is stuck on the rock so that it can send power to the other front tire that is up in the air.)--Can Am owner
12-20-2011, 06:59 PM
Member #21001
looks like we have the same question, but why the 14" wheels?
12-21-2011, 02:02 AM
Member #7365
Just personal preference. I just like the look of a 14 on a 27 + inch tire.
12-22-2011, 06:16 AM
Member #19986
I like the way you think!
You have probably seen some pictures of 14" wheels on the full size Polaris. They do make an impression. I like the idea of a shorter sidewall to achieve the 27" tire diameter. It all starts to look a little like a hot wheels model but you add ground clearance without modifying the suspension. Backspacing is one thing but tire width trumps that when it comes to suspension component interference.
My intention is to find a dealer with a tech support phone number. I'll decide on the wheel and tire style combination and call them to qualify the fitment. This is my suggestion to you as well.
2006 Sportsman 800 EFI - purchased 10-2011
12-22-2011, 07:46 AM
Member #7365
Thats a good idea.
I think I may call my dealer or mud throwers and ask them a few questions about the wheels and tires I described and see what they say.
12-24-2011, 09:41 AM
Member #7365
So I've changed my mind yet again, I'm going to go with some 14" MSA M12 wheels and stay with the swamp lites. Now all I'm really wondering is if I'm going to need wheel spacers for the front 2 wheels since the the tires in the front will be 27-9-14, thats an extra inch of width on the tire size compared to the stock tires.
12-24-2011, 01:34 PM
Member #7031
You should be fine. But I'm not 100% sure
2003 Sportsman 700
Windshield-Polaris Billet gas cap-Billet Shifter
Kolpin 3way hitch-Kolpin Fuel pack-Kolpin Rear Seat
Diamond plate boot guards-radiator cover-racks
2000lb winch-Custom front bumper with enough light to turn night into day!
Custom mounted rear winch
Polaris rear grab bar
Big Gun full exhaust, soon to be dual exhaust!!
Pure Polaris Black aluminum skids
Uni air filter
COMING SOON
28" ol2's skinny wide or 28" terms skinny wide
On 14" hd3 rims
12-24-2011, 03:50 PM
Member #19986
You can take a careful look at the clearance that you have now and determine if there is another half inch to spare; keeping in mind the rim of the wheel will extend upward an additional inch. However, if you do investigate by calling your dealer or seller, ask what the 4+3 back spacing actually means. Then, please post that information here.
12-24-2011, 04:11 PM
Member #7031
Here is how to read backspacing. The tires will fit fine with the right backspace.
2003 Sportsman 700
Uni air filter
COMING SOON
On 14" hd3 rims
12-24-2011, 08:01 PM
Member #19986
This is great! I hope the moderator sticks this here and it finds its way to becoming a FAQ answer.
It is different than the way automotive back spacing is defined.
05 polaris 800 sportsman 27/9/14 front tire, 14 inch sti wheels for sportsman 800, 14 inch wheels on a polaris sportsman 800 x2, 27 inch executioners on sportsman 800, 27 inch tires work on stock 2003 polaris 700, atv rims questions, is there room for 9 inch tires on 2012 polaris sportsman 800, polaris scrambler 500 tire and wheel packages, polaris scrambler tire packages, polaris scrambler wheel and tire package, razor sportsman wheels fit a 500 spacers, razor wheels on my sportsman 800efi, rim fitting questions, scrambler tire wheel package, wheel spacers 2012 polaris, wheel spacers for a 2003 polaris sportsman 700, wil c7 rim fit on 800 sportsman, will 27 inch tires harm my polaris sportsman 800, will a 10 inch tire fit on the front of a polaris 500 ho with aftermarket wheels, will razor wheels fit on sportsman 500 ho
