Old 12-31-2011, 07:38 AM
Z-Rider's Avatar
Member #680
Tire recommendations....
Looking to upgrade tires on my 2012 Sportsman 500 HO in the next month or so. Personally want to run the stock wheels as I will just end up scratching up a nice set of aluminums. With that being said what would be some tires to look at?
Stock tires are 25x8-12 on the front and 25x10-12 on the rear and I would like to go up to maybe a 26 or 27" tire. Don't want to go to large to where I am in need of a clutch kit or other mods. The quad does not have a lift kit and will not have one.
Let me know what my options are. Looked at Maxxis Big Horns or GBC Grim Reapers. I ride mostly hradpack trails and some intermitent mud but nothing extreme.
Thanks for any help provided,
Z
Old 12-31-2011, 03:39 PM
racer37l's Avatar
Member #5629
By not wanting to use a clutch kit, you have narrowed your choices to the 26" tires IMO. You may still need a different primary spring if you choose Bighorns or tires that will be heavier than your stockers (as most will be). I put a spring in mine when I put my Bighorns on.
Another thing to consider will be that most replacement tires is that about all of them will be wider on the front. In that case you may have to use small spacers(1/4-3/8") to have clearance from the tierod end.
That being said, my suggestion is the Bighorns at 26" tall.
Good luck!
Con
Old 12-31-2011, 04:54 PM
vortecz71wv's Avatar
Member #14032
I am running the GBC Dirt Commanders and my wife's bike has the GBC Grim Reapers. Both 8-ply so we dont need to be extremely worried about punctures and they ride awesome! The only reason we did not go with the BigHorns is because everyone we ride with has them and wanted to roll on something different. Overall we are very happy with these tires!
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless
Fuel It, Flog It, Feel It!
Old 12-31-2011, 06:50 PM
bobx2's Avatar
Member #14376
I agree with racer371 about going with 26" Bighorns. 26-9-12 front and 26-12-12 rear. As he said you will need wheel spacers or different wheels for clearance on the front. However, I don't think any clutch work will be needed. Run 26" BH's on the wifes '09 500 with no problems at all. Really can't beat the BH's for a great all around tire that is still reasonably priced. Tough 6 ply radial tire that rides better than OEM 2 & 3 ply tires. I've ridden some tough country and have never had a flat with the BH's. Great tires!
Old 12-31-2011, 07:11 PM
Z-Rider's Avatar
Member #680
I am not opposed to clutch work as I have clutched my sleds in the past. What primary spring should I consider if I run the Bighorns in a 26" tire?
Old 01-02-2012, 04:29 PM
AndymcXP850's Avatar
Member #11578
ATV Television Tech - All Season, All Year, Big Time, Long Term Tire Test - YouTube
Its about time someone did a tire test like this! By the end we should all have a good idea of which kind of tire best suits our needs.
Old 01-02-2012, 06:26 PM
bobx2's Avatar
Member #14376
I'm amazed he picked Polaris machines. Any time he does a test on them, he always bad mouths and nit-picks them to death. Mostly it is the 4x4 system he claims to hate. I personally feel that it is the best out there.
Should be interesting to follow along.
26 maxxis bighorns polaris 500
26 or 27 tires 02 500 polaris
26 or 27's on sportsman 500
atv tire recomendation
atv tire recommendation for polaris 800
atv tire recommendations
biggest tire on stock 800efi
bighorn sportsman 800 26/9/12 fitment
bighorns vs grim reaper
clutch kit for grim reaper tire
grim reaper or bighorns
i have 27' tires on my polaris 500 what clucth kit i need
stock replacement tires
tire recommendation for 2012 sportsman 500
Oil recommendations? Squanto10 ATV General Discussion 12 07-20-2011 04:15 AM
Polaris 525-S Need your exhaust recommendations detonate Polaris Outlaw 26 06-06-2011 09:09 PM
Belt Recommendations dgdubya ATV Repair and Maintenance 9 03-04-2011 01:52 AM
Ok...ready to buy...your recommendations? Orion6 ATV General Discussion 7 01-25-2011 07:17 AM
Faring recommendations jpolcher Polaris XP 5 01-02-2011 08:16 AM
