Old 01-03-2012, 05:55 PM
RHGuyettejr's Avatar
Member #21940
02' Sportsman 400 wheel questions
Hello,
I am new to the forum and joined because I had a few questions I figured somebody on here could help me with. I recently purchased an 02 sportsman 400 with 70hrs on it and want to make it look a little bit better. I am looking at wheels but I am kind of lost about what to even consider. First I would like to go with the same size wheel all the way around which of course means I will need to swap tires in the rear as well, but are there two different bolt patterns for the front and back? Most of the wheels I find are listed only for the front or only for the rear, is this simply because the company goes by stock wheel size or does it have to do with the bolt pattern. Also will I run into any issues with the hubs fitting through any wheels in particular? I would like to run something like this...
STI HD1 Alloy Wheel | ATV | Rocky Mountain ATV/MC
Thanks for any help from anybody who can point me in the right direction. These wheels in particular are noted to only fit the front of the machine.
2002 Polaris Sportsman 400 4x4
Old 01-03-2012, 08:07 PM
Old 01-04-2012, 01:41 PM
Member #21940
Thanks man.
Old 01-10-2012, 02:22 PM
Member #21940
I have found some wheels I like, but they are a 12 inch wheel..... will this be to large for a 400? I will plan on running a lower profile tire and want to avoid a lift or raising the height of the machine too much.
Old 01-10-2012, 05:12 PM
atv king's Avatar
Member #7031
12" wide is what's on the front and probably 10" on the back but you can run 12" front and back. The only thing is you need different bolt patterns for the front and rear 4/156 for the front and 4/4 for the rear so I think wheel selection is pretty limited.
2003 Sportsman 700
Windshield-Polaris Billet gas cap-Billet Shifter
Kolpin 3way hitch-Kolpin Fuel pack-Kolpin Rear Seat
Diamond plate boot guards-radiator cover-racks
2000lb winch-Custom front bumper with enough light to turn night into day!
Custom mounted rear winch
Polaris rear grab bar
Big Gun full exhaust, soon to be dual exhaust!!
Pure Polaris Black aluminum skids
Uni air filter
COMING SOON
28" ol2's skinny wide or 28" terms skinny wide
On 14" hd3 rims
Old 01-11-2012, 06:16 PM
Member #21940
Thanks for the reply... I did happen to find an adapter shop that makes custom adapters, and then I would have to run a 1 inch spacer on the front to even out the wheels, which I wouldn't mind having a wider stance. Only thing is they are a bit pricy for a 4/4 to 4/156 conversion at $60.00 a piece and can be found here (4 Lug ATV to 4 Lug ATV : ATV Wheel Adapters : 4 Lug Wheel Adapters : AdapterKing). I am thinking I can have my brother make some spacers for the front on the CNC at school. Now at least I know what I am getting into when I go to do this. Also just out of curiosity does there happen to be a hub that would fit and has a 4/156 pattern for the back? Could front hubs be placed on the rear? I am not really sure what goes into swapping a hub on these things so this question is just more for my knowledge than anything. Thanks again.
Old 01-11-2012, 06:23 PM
atv king's Avatar
Member #7031
You don't have to use adapters if you don't want to I found this picture of a scrambler with 12" itp108 and it looks pretty good.
2003 Sportsman 700
Uni air filter
COMING SOON
On 14" hd3 rims
Old 01-11-2012, 06:27 PM
Member #21940
That does look good, I am just having trouble finding wheels I want that are available in both 4/156 and 4/4 bolt pattern. I'm thinking I may just give ITP a call some time and ask what models they offer with these bolt patterns, as some sites don't seem to list the bolt patterns just whether or not it fits a certain model.
02 polaris 400 sportsman forum
02 sportsman 400 tire size
2002 polaris 400 sportman tire size
2002 polaris sportsman 400
2002 polaris sportsman 400 wheel size
2002 polaris sportsman 400 wheel spacing adapter
2002 sportsman 400 tires size
4/4 to 4/156 wheel adapters
atv with hd3 wheels
factory 2002 polaris sportsman 400 tires size
how big of tires can you put on a stock polaris sportsman
how to pack wheel bearing polaris 400 sportsman
rocky mountain atv
sportsman 400 2010 rims size
sportsman 400 bolt pattern
sportsman 400 tire fitment
sportsman 400 wheel specs
sti hd1 on sportsman
sti hd1 wheels
what size is the tire on front and rear for 2002 sportsman 400 polaris
2010 850xp wheel questions Boodro ATV Wheels & Tires 14 11-15-2011 08:45 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 ATV Repair and Maintenance 5 03-23-2011 11:01 AM
Tire size & wheel questions & thoughts. scottdeet ATV Wheels & Tires 9 03-11-2011 12:58 PM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
2005 Polaris Sportsman 400 wheel bearing questions? tcj198 ATV Repair and Maintenance 0 10-07-2010 02:14 PM
