You will need to put the same size spacer all the way around if you do not want the front to be wider than the rear. It will be more difficult to steer, but if you ride a lot of mud, you will like the wides. Wides pull better and will keep you from digging down in the mud like a skinny would do.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
