  #11 (permalink)
Old 01-28-2012, 06:56 PM
Rooskey's Avatar
Member #22134
Originally Posted by PawPaw View Post
These Mudlite XTR radial's are over 2 yr's old and doing great in my riding area.
Wow, great tread life. How many miles on those tires?
  #12 (permalink)
Old 01-28-2012, 07:01 PM
800touring's Avatar
Member #14149
how many miles on the xtrs I just got a set for my 850 and love them but my bikes in the shop tho so cant use them
  #13 (permalink)
Old 01-28-2012, 07:03 PM
lod666ftw's Avatar
Member #14566
You probably wont have the problems that I mentioned. I would clutch it, you probably will lose a little top speed clutchin but it will be worth the extra power you gain off the bottom end! The old design on the belt in my opinion is bullet proof. The XP's have a smaller belt system. The 850 have alot more power off bottom in high range and stock clutch tends to slip when clutch is engaged.JMO!
2011 850 XP pursuit camo
26" Sedona Ripsaw Tires
Lock and ride front box
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
  #14 (permalink)
Old 01-28-2012, 07:07 PM
lod666ftw's Avatar
Member #14566
Oh yea my 500 ho has XTR mudlites and there are a great tire but are heavy to. The XTR's were the first radial mud tire that I know of. Great tire just not what I am lookin for on my 850!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
  #15 (permalink)
Old 01-29-2012, 12:52 PM
gtxgohan's Avatar
Member #11816
Thumbs up
Originally Posted by Rooskey View Post
Originally Posted by lod666ftw View Post
The ripsaws are extremely heavy tires Period. They will make your bike shake alot! I know mine would sway back and forth in the rear like and old homemade tow behind trailer down the road at 70 or more! They will go any where but get your wallet out for bushings, ball joints and belts. They grip so well when you crack the throttle at slow speed you will fry your belt!!! Run low range in woods if you dont plan on goin over 40. Running low is a must in mud!! Oh yea dont forget you will be pressure washing alot of mud cause they throw it all over You and the wheeler!!
Thanks for the reply. I understand by gripping so much they will put extra strain on the belt but what is the deal with the bushing's and ball joints? Should I look into a clutch kit too?
reason for bushing is the more weight is being thrown around by that once your bushing and tie rods go your bike will start hitting tire and when u make turns it going to sound like your braking stuff when making sharp turns and going over and under stuff every pot hole u hit ur gonna hear tie rods are simple too fix so are bushing just time consuming and please grease them up cause it will save u so much trouble in the long run especially if you do all everything yourself
2001 Polaris sportsman 400 4x4 olive/ sage green
  #16 (permalink)
Old 01-29-2012, 02:33 PM
lod666ftw's Avatar
Member #14566
I just said probably, I have a 500 ho with 10000 miles on it and havent had much problem with bushings. I had 1 bolt break in rear suspensionand bushing fell out but that has been about it. Hell Ive never changed brakes on the old beast. I would love to have the power in the 850 xp in the old frame and suspension design. They were bullet proof. I am currently getting motor rebuilt in 500 and gonna use for hunting only. Its alot easier to putt around on then my 850!
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
polaris tires and wheels benefits
ripsaw atv tire cons
how much power loss w/ 28 outlaw radials? 4x4addict ATV General Discussion 0 08-11-2011 02:41 PM
Outlaw radials xxlsutigersxx ATV Wheels & Tires 4 07-24-2011 08:23 PM
Outlaw Radials VS Maxxis Zillas maboree ATV Wheels & Tires 26 12-22-2010 06:22 AM
Maxxis Mudbug radials jefost8 ATV General Discussion 7 10-07-2010 05:00 PM
whats better radials or 6ply ? johnnyjaws ATV Wheels & Tires 3 09-10-2010 02:15 AM
