Old 01-29-2012, 11:14 AM
cjr's Avatar
cjr cjr is offline
Member #17374
27 inch tires
I order a set of 27 inch tires. Went wider on front. Stock are 25x8x12 front and rear is 25x10x12. I went with 27x10x12 front and 27x12x12 rear. I have a 2004 500 ho sportsman. Do I need to buy wheel spacer's for the front or will they be good?
Old 01-29-2012, 11:21 AM
chopper89's Avatar
Member #1634
if your using your stock rims you will need spacers on the front, the tie rod end will rub your tires. if you got aftermarket rims depending on the offset they should clear.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 01-29-2012, 11:23 AM
cjr's Avatar
cjr cjr is offline
Member #17374
Ok thank. I was thinking that. I will order a set. I have stock rims. Know any good place to order them from.
Old 01-29-2012, 11:34 AM
chopper89's Avatar
Member #1634
couldnt get the link to work google rockymountain atv there pretty good outfit.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
10 inch wide tires on stock polaris sportsman 500 wheels
12 or 14 inch tires polaris 500
14 inch polaris wheels
14 inch wheel for polaris 500
14 inch wheels polaris 500
26 or 27 inch 500 polaris
27 inch tires on polaris
27 inch tires on stock polaris 500 ho
27 inch tires stock sportsman 800
28 inch tires on stock polaris 500 ho
28 inch tires polaris 500
a t v 14 inch tires
biggest tires on polaris 800 sportsman
polaris 800 xp rims tire 27 inch
polaris 850 with 27 inch tires
polaris sportsman 500 14 inch chrom rim
polaris sportsman 800 27 inch tires
polaris sportsman 800 will 14 inch wheels clear tie rods
polaris sportsman 800 wsith 27 inch tires
will 27 inch tires fit on stock polaris 500 with stock rims
25 inch Tires 0n 2009 midsize 400 HO Polaris Bear ATV Wheels & Tires 1 01-20-2012 10:24 AM
27 or 28 inch ITP 589m/s Mudisfun ATV Wheels & Tires 11 03-30-2011 06:29 PM
do i need a lift and spacers to make 27 inch tires fit on stock 2011 sportsman 500? solid_crimson ATV Wheels & Tires 2 03-24-2011 05:56 AM
26 inch tires for 14 inch rims $150.00 Naga ATV Parts for Sale 3 01-05-2011 05:20 PM
12 inch wheels on xp! in2deep Xp ATV General Discussion 3 03-03-2010 06:07 PM
