Old 01-31-2012, 08:25 AM
Member #1958
Will RZR wheels work on my Sportsman?
I've found a set of RZR take off wheels and wondered if they'll work on my 800 sportsman with OEM size tires and if there would be any difference in offset or lugs? I know the bolt pattern is the same but would there be any other issues?
Old 02-03-2012, 04:32 PM
Wes's Avatar
Wes Wes is offline
Member #6903
Wow, same question. But these 14" Vision wheel bolt holes are larger than the stock aluminum wheel bolt holes.(?)
Old 02-03-2012, 06:13 PM
kool_500HO's Avatar
Member #11710
I'm running my outlaws on take off steel wheels from a RZR
2011 Polaris Sportsman 500 HO
6000K HID's,Kimpex fender guards,foot pegs,rear seat,Polaris Front/Rear bumpers,2500lb winch,Handguards,ITP SS 12" 212 machined wheels,ITP Mudlite XL 26" tires,Highlifter springs Front/Rear,26" Outlaws,QSC clutch kit/Exhaust,UNI filter,Ricochet A-Arm guards...More coming soon...Kinda running out of stuff to buy though!
Old 02-04-2012, 03:41 AM
Wes's Avatar
Wes Wes is offline
Member #6903
Do the RZR's have bigger diameter wheel studs hence the bigger bolt hole or do I need different lug nuts?
Old 02-04-2012, 05:47 PM
Wes's Avatar
Wes Wes is offline
Member #6903
Ok. Well these wheels are from a Polaris, but not a RZR as I was told. The holes are 1/2" so they won't fit my Sportsman unless I use a adapter. Had the tires peeled off and bought some Buckshots at the dealer today.
So up for sale 2 14x8 and 2 14x7 4/156. 200 bucks +shipping.
Old 02-04-2012, 06:35 PM
ZPO's Avatar
ZPO ZPO is offline
Member #21790
Wes,
I'm confused. What Polaris were they from.
On another note----->
I know my dealer says if I change from the stock steel wheels on my 2011 850 X2 to the Aluminum Polaris wheels they require a different set of lug nuts (per what they show in their catalog.)
2011 Sportsman 850 X2 LE Sage Green
Old 02-04-2012, 07:03 PM
Wes's Avatar
Wes Wes is offline
Member #6903
Say 02-06 Magnum 500 with 1/2" studs? The rear are 1/2, are the front the same or are they 3/8?
Stamped on the insde on one set was 4444S and on the other was 4464S.
2012 polaris rzr 800 bolt stock pattern
2012 sportsman 500 wheel pattern
are polaris rzr wheels the same as sportsman
atv wheels
do rims off a rzr fir a sportsman
does rzr wheels fit sportsman
polaris razor 800 takeoff wheels/tires
polaris sportsman front steel wheel interchange
rzr steel wheel
rzr wheels fit sportsman#gsc.tab
sportsman rzr rims
what size are polaris rzr wheel stud#gsc.tab
will polaris rzr wheels fit a a sportsman 500
will razor wheels fit on sportsman 500 ho
will rzr rims fit on sportsman 500
will rzr wheels fit a 500 sportsman
will stock wheels off a polaris rzr fit on a polaris sportsman
will the wheels of a polaris rzr will fit polaris sportsman 500
will the wheels off of a 2012 polaris razor 800 fit on a polaris sportsman 500ho
will wheels from rzr fit polaris sportsman
'95 Sportsman Needs Some Work LA Confederate ATV Repair and Maintenance 6 03-01-2012 02:18 PM
04 sportsman 500 AWD won't work donkey ATV Repair and Maintenance 5 09-24-2011 09:52 AM
brakes work great than they dont. then work agian thepopeis1 ATV Brakes & Suspension 1 08-07-2011 04:07 PM
04 sportsman 4x4 won't work Polarisguy57 ATV Repair and Maintenance 9 06-28-2011 03:54 PM
How much work are you doing with you Sportsman 400/500? WilliamBos Polaris Sportsman 3 03-13-2011 04:09 PM
