i have a 2000 400 xplorer and the rear tires are 25x11x10 can i put on the next size bigger tire and use the same rim if I can what would be the next size,Thanks
From all the looking and checking that I have done. To go to a 26in tire you will have to change the rims. At this time I have not found a 26in tire with a 10in rim only using the 12 and 14 in rims. You can go wider and that would be a 25x12x10.
