  #11 (permalink)
Old 02-08-2012, 01:55 PM
cupero's Avatar
Member #19840
and if i stay with the stock 12s and if i do get the swamp lites they wont rub will they
  #12 (permalink)
Old 02-08-2012, 04:09 PM
jac42779's Avatar
Member #17976
I would think that you would be ok with the stock rims if you stay with the original size tires if they make them in that tire. You may be able to even go up a size. Sorry for not having a real answer, maybe someone that knows more than me will give you an answer.
I just bought the pitbull growlers from discount tire direct in the 25.5 size and they are real close to the same size as my original tires and look great. I have not put any time on them yet but going on a big 4 day ride in april. The front tires are about an inch wider and taller than my stock tires. The back ones look to be exact the same size.
  #13 (permalink)
Old 02-08-2012, 05:04 PM
bobx2's Avatar
Member #14376
9" wide front tires on the stock wheels will rub on the tie rod ends. If you go bigger than stock and want to keep your OE rims, you might take a look at some wheel spacers. Cheaper than new wheels.
  #14 (permalink)
Old 02-09-2012, 02:56 AM
cupero's Avatar
Member #19840
how realiable are wheel spacers..
how big of a tire for a polaris 800
polaris 800 tires
wheel and tire links
Suggestions please! cov62431 ATV Performance Modifications 10 02-16-2012 08:58 PM
Tire/Wheel suggestions for my 2010 Sportsman 500?? Twitch2146 ATV Wheels & Tires 7 02-02-2012 09:33 AM
wheel/tire combo & clutch suggestions please.. apextrans Polaris Scrambler 5 11-03-2011 05:23 PM
Tire and Wheel suggestions XP850? rswansondive ATV Wheels & Tires 8 09-12-2011 05:34 AM
01 Sportsman 400, Tire upgrade suggestions? turbocav22 ATV Wheels & Tires 2 04-07-2010 04:04 PM
