Old 02-06-2012, 08:17 PM
Timvan's Avatar
Member #23021
27" or 28" zillas
Hi iam trying to decide between 27 or 28 in zilla tires for my new 850. I have been told that zilla tires actualy measure small so I am leaning towards the 28s but do you think that will be the best fit thanks for any input.
Old 02-06-2012, 10:03 PM
lasportsman3's Avatar
Member #22654
i'd get 28's. if it runs small at all its less than 1/2". i'll try to remember to get actual measurement this weekend
2011 Polaris Sportsman 400 H.O.
28" Zillas w/ SS108s
2" RDC Lift
Green LEDS
Old 02-07-2012, 04:40 AM
Timvan's Avatar
Member #23021
Thanks I just want make sure Thay wont rub iam getting after market wheel but I don't want to have to lift the bike or use wheel spacers.
Old 02-07-2012, 10:38 AM
lod666ftw's Avatar
Member #14566
I have read alot about guys running 28's on 850's and the usual sidewall ply ratings. I think everyone that has owned a set of zillas and commented on here has the same answer. best tire they ever had. I personally havent had them but have been lookin at them alot. I have read countless posts and looked up as much info as I could find. Everyone likes them that has them and most state they would buy again. I know weight and size wise they sure look good. I personally dont like heavy tires, tried that and wasnt pleased. They say 28's are more like 27's and if you go with 27's you have to get the wider 10 inch tire upfront. I wouldnt want this myself maybe you do. I would perfer 28x9x14 vs 27x10x14 up front! I guess I need to just buy a set because the price is very good for 28's and the weight is closer to stock than all you aftermarket radial or bias in 26 inch! JMI.
2011 850 XP pursuit camo
26" Sedona Ripsaw Tires
Lock and ride front box
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 02-07-2012, 04:11 PM
Timvan's Avatar
Member #23021
Thanks very much your comments help a lot and I think the 28s will be the best fit for me.
Old 02-07-2012, 06:19 PM
lost cause's Avatar
Member #9763
Go with the 28's. You can fit 30's on these machines with no lift.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 02-09-2012, 02:54 PM
mountie's Avatar
Member #22232
I had planned to put 27's on my new 850X2. But now I may be tempted by the 28's. Will these tires require any upgrade of the clutch or belt?
2011 850 X2, Smittybilt 3000 XRC winch. Front steel rack extension. Winch saver. Lock and Ride Windshield. 27 inch Zilla Tires. Moose Front Bumper. Remote Booster Cables. Quadovator Reverse Overide Switch. Polaris Plow. Rear A Arm Guards.
Old 02-09-2012, 07:29 PM
wishiwasfishin's Avatar
Member #14854
The zilla's run small. So 28's will fit with no problem. They are also super light.
So an 850 will think you just have stock tires. I run 28" Radial Outlaws. The radial laws are super heavy. But, my 550 handles them fine with no mods.
2011 Sportsman 550
14" High Lifter XL2 wheels
28" Outlaw Radials
3500# Viper Max winch
3" High Lifter Signature lift
2009 Honda Rancher AT
14" ITP wheels
26" zillas
2003 Rancher ES
14" ITP wheels
26" Mud Trax Tires
3000# Gorilla winch
High Lifter lift springs
Old 02-09-2012, 10:53 PM
mountie's Avatar
Member #22232
Thanks man. Sorry didn't mean to hijack your thread.
Old 02-11-2012, 03:55 PM
PawPaw's Avatar
Member #962
They'll work great on your 850 with no mod's. Will look great on the stock wheel's too.
27 vs 28 atv tires
28 zillas polaris
can i run a outlaw tire on my 2012 sportsman 400
do zilla tires measure small
how well will 27 inch zillas perform on 350 rancher?
pics of 2012 polaris sportsman 400 ho with aftermarket rim and tires
what do 28'' atv super lights measure
zillas 27
28" or 30" zillas demon550xp ATV Wheels & Tires 28 02-02-2012 07:33 PM
30" zillas Raimey Polaris XP 5 05-08-2011 06:53 AM
28" zillas taylormade1ca ATV Wheels & Tires 5 04-19-2011 07:49 PM
Polaris 700 Twin EFI... "Wait" and "End" Error? TechieSooner Polaris Sportsman 3 11-26-2010 06:20 PM
30" Zillas messinaround ATV Performance Modifications 0 04-30-2010 12:24 PM
