05-04-2009, 09:45 AM
Member #403
Maxxis Bighorns on 800
Has anyone used the 26" Bighorns on their 800? They are actually a true 27". I was just worried about rubbing issues. I was going to go with ITP SS112 rims.
05-12-2009, 12:47 PM
Member #448
I have had the big hornies on a 500,800 and 850 all on ss212s and there is no rubbing issue The big hornes are great tires.
09 Sportsman 850 XP
Ric.arm gaurds, piaa lights, tammarack rear box Audio Pipe Otter armor ,Otter RAM mount,ss 212, big hornies,HMF swamp searies more to come
07 Sportsman 500 H.O. sunburst red Ric. A-arm gaurds Hilifter springs UNI Tamarack soft side rear box Full body armor ss 212 14" big Hornies ( Wifes)
Windrock ATV Club Trail Guid
Cumberland ATV Ridders
Heart of Dixie Riders Founder
Mountain High Club President
It's Better To Have Than Want I Know I've been There
07-25-2009, 05:56 AM
Member #927
If you use your stock wheels, they will fit fine, but you have to flip your front upper tirod ends. Form the factory they are setting on top, and the added width of the new front tires will hit them. If you un bolt them and then place the tirod on the bottom of the bracket it then lines up with the rim and not the tire, hince no more rubbing issue. If you do not want to flip the tierods you have to go with aftermarket rims, and the machine will be a couple inchs wider than with the factory rims do to the added offset of the aftermarket rims, but its that added offset that allows the tires to clear the tierods in there factory mounting position.
07-25-2009, 05:59 PM
Member #927
Here are some pics of 26" bighorns on 12" OEM rims. Also some pics of the tirod that they hit unless you flip over to the other side of that bracket pictured there. Once it is on the other side of the bracket it lines up with the rim and not the tire, so you can how ever big a tire you want and it will not effect the tirod ends.
Current Quads:
2011 Polaris Sportsman 850XP EPS LE Touring (Graphite)
2009 Polaris Sportsman 850XP EPS (Stealth Black)
2008 Polaris Sportsman 90 (Stealth Black)
Past Polaris Quads:
2010 Sportsman black 850 eps, 2008 black LE X2 800
2008 Polaris RZR 800, 2005 Polaris Sporstman 800, 2002 Trail Boss 325, 2001 Sportsman 500, 2000 Sportsman 500, 1999 Scrambler,
10-01-2009, 12:26 PM
Member #1566
Very nice ride CC1999!
10-04-2009, 08:06 PM
Member #1457
I took your advice and flipped the tie rod ends. The clearence appears to be perfect. I think you should mention that you must adjust the toe in after you flip the tie rod ends. It is very simple to do, no special tools or anything.
10-15-2009, 07:50 PM
Member #1652
Anyone running the 26" BH tires with 14" Vs. 11" stock dims?
My thoughts are with the newer XP's running the Terrathons at 14" increases the stance a little. Maybe I can can a little stability? Opinions?
R'
26 wheel and tire polaris 800 x2, 26x12x12 maxxis big horn tire on stock polaris rzr ?, 27 bighorn outlander 800r, 27 maxxis bighorn on stock polaris rzr, aftermarket 12" polaris maxxis bighorns, can i run 26x12x12 maxxis big horns on my 800 rzr, do maxxis bighorn tires on polaris sportsman 800, flipping tie rod end polaris sportsman, flipping tie rod end sportsman 500, how to flip tie rod on sportsman for tire clearence, maxxis bighorn atv tires polaris sportsman, maxxis bighorn tires for polaris sportsman 800, maxxis bighorns for polaris 800s, maxxis bighorns on polaris x2, what is the widest tire 2006 polaris 800, who has maxxis bighorns in stock, will 26 bighorns fit on polaris x2, will 27'' tires fit 800 sportsman, will 27'' tires fit stock 800 sportsman, will maxxis bigorn 27 fit
