06-19-2012, 09:06 PM
Member #10066
Pros and cons between 12" and 14" wheel and tire
I will be purchasing wheels and tires soon. I have made the decision to go with the Pitbull rockers and have a couple wheels that I am debating. So, now I am wondering what the difference is between a 12" and 14" set up. Obviously the wheel is larger on the 14" and the sidewall is shorter, but what else. The 14"s probably look better, more wheel less rubber. Not a huge difference in cost to go to the 14"s either. Hmmm..... Help please!
06-19-2012, 09:16 PM
Member #11247
14s will steer nicer, 12s will ride smoother.
Sent from my SCH-I510 using Tapatalk 2
2013 Sportsman 500 H.O. - Guru brush guard, 26" Big Horns, RDC 1/4" spacers, Viper Max 2500lb winch, EPI HD front springs
2011 Sportsman 500 H.O. - Guru brush guard, 26" Big Horns, RDC 1/4" spacers, gutted muffler, Polaris 2500, Polaris HD front springs, Polaris heated grips, Glacier III 60" plow, Quadovator reverse mod, 3 headlight mod, Polaris rear rack extender, rear L&R cargo box, HIDs SOLD
2011 Trail Boss - HIDs SOLD
06-20-2012, 03:50 AM
Member #23200
I would think if you ride in really rocky terrain the 14's would get beat up more
06-20-2012, 07:06 AM
Member #14376
From personal experience I would stick with 12" wheels. If I could put 12's on my XP, I would do it. The 14's don't give you as much sidewall flex and you need to run higher tire pressures to help protect the wheels and tire sidewalls. Lower pressure gives you a better ride in the rough stuff, bigger footprint and better tire flex in the rocks. The only reason I could see to switch to 14's would be if you were into high speed riding and wanted a lower profile tire. That being said, I never had any problems with the sidewall rolling on my 800. An increase of a couple of psi with the 12's would take care of that if it was a problem. With the thickness of the sidewalls in the Rockers I don't think you would have that problem anyway.
'11 XP 850 EPS, 26.5 Pitbull Rockers on STI HD2 Wheels, Warn XT25, Ricochet Ultimate protection, Elka Stage 1 shocks
'09 Sportsman 500 EFI HO, 26" Maxxis Bighorns, Polaris 2,500 lb. winch, Cycle Country plow
06-20-2012, 09:22 PM
Member #10066
No high speed riding here. Softer ride and more wheel protection and grip on rocks is better for me. So, I will stay with the 12"inchers.
06-21-2012, 12:37 AM
Member #4618
You staying with the same size (i.e. 26, 27, 28) tires? I think the 1" (this is the actual sidewall distance we are talking about) is negligible in the wheel size as far as ride or performance goes. If it is important to you, get a larger tire.
2010 Sportsman 550 EFI
Warn XT25 on KFI Mount, Polaris Rear Cargo Box "Lock 'n Ride", Lowrance Baja 540C GPS, Custom front rack (for ice-fishing) "Lock 'n Ride" mounted, Front Cargo Box, ATV-Guru Cobra Brush Guards (with full expanded metal) Front & Rear. Maxxis Bighorns. Lock n' RideTall Windshield. Grip & Thumb Warmers. Tatou 4s Track System. High Lifter HD springs all around.
More mods to come.
06-22-2012, 12:29 PM
Member #11270
Keep in mind the PitBull tires run 1/2 inch larger than the size indicates.
Let us know if we can be of assistance.
06-29-2012, 11:11 PM
Member #27523
I'll prefer to the 12s wheel. because in 12s wheel you can ride smooth which is always required to me. But hose all 12s should be perfect in occurrence.
06-30-2012, 08:24 PM
Member #10057
Exactly, I would "hose all 12s"... Well maybe not "hose" all of them because... I really have no idea how much time/effort that would take...
2011 Sportsman 550 X2
Ricochet Ultimate Armor
2005 Honda Rancher 400
2005 Honda Recon
12 inch or 14 inch ranger, 12 or 14 atv wheels, 12 or 14 in atv rims, 12 vs 14 atv wheels, 12 vs 14 atv wheels#gsc.tab, 12 vs 14 wheels polaris ranger, 14 inch wheels for atv, can i put 14 inch wheels 2013 sportsman, differance between 12 and 14 rims, polaris 14 inch wheels, polaris 14 wheels, polaris 500 12 or 14 inch rims, utv pro & cons, what is the different between 14in., which is better for atv wheels, 12 or 14
