Old 07-05-2012, 06:01 AM
Maniac's Avatar
Member #3325
Pitbull Growler Tires
I got some nice riding in yesterday with the new tires. This is my third decent length trip that I put on them. They have been excellent so far. I am still looking for that sweet spot for the tire pressure. I started at a high pressure and have been dropping weight 1/4 lb at a time. I am going to take it down to 5 psi next time.
I decided to attempt to cross a creek yesterday that I never was able to with my OEM tires. The creek has a very soft mud bottom and I only made it to the other side in AWD in the past, but was never able to climb the bank. Well that was before yesterday. I made it across the creek in 2wd. (These tires clean out very nice for being a trail tire.) Then in AWD after one failed attempt, I made it up that bank that I never was able to climb before. Impressive!!!
I drove over several wet logs without much of an issue. I wasn't overly impressed with crawling over the logs. Not better.. Not worse...
I climbed a few hills that I haven't tried in a while. On those steep hills I did notice that my engine was working harder than normal, but I think it was mostly due to these tires digging in more than the OEMs. And wow do they dig! I was able to glance back at one point and it looked like I was a speed boat in the water spraying up water. (or dirt in my case)
I do notice a little power loss when wide open. It takes a little longer to reach top speed, but I rarely am able to run wide open where I ride. The only other negative so far is that I can feel everything under the tires. I think that it is due to being a radial tire. (and not flexing as much as bias ply) I hit a rocky section and I got beat up a little. I am adjusting the tire pressure to see if that makes any difference.
Overall, these tires are excellent. The handling and steering of these tires are amazing! I have put them through some difficult conditions and they haven't left me down yet. Time will tell how they hold up.
09' Sportsman 800 Touring - K&N Filter & PreFilter - Dalton Primary Clutch Spring - Polaris 3500 Winch - Deluxe Front Brush Guard - Rear Bumper - Polaris 60" Plow - Handguards - 3 Headlight Mod - Amsteel Winch Rope -Pitbull 25.5" Growler Tires
Old 07-05-2012, 08:48 AM
Discount Tire's Avatar
Member #11270
Thanks for your report of the PitBull Growlers in action. Sounds like you picked up the right tire for your type of riding.
Sounds like a fun ride.
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Shop ATV/UTV Tires
Shop ATV/UTV Wheels
Current Promotions
Old 07-05-2012, 11:59 AM
gtsum2's Avatar
Member #23200
nice and thorough review!
Old 07-05-2012, 12:03 PM
JimmyC's Avatar
Member #23401
I love the look of the pit bulls and for the type of riding I do (aggressive trail riding) they look like the perfect tire.
I'm pretty sure as soon as I wear out zillas I'll be grabbing a set of the Growlers. Did you happen to look at the Uber Growlers? Looks like they'll be a little heavier because of the 8 vs 6 ply but I'd rather have a little more durability than win any speed contests.
Can you really tell a difference in adjusting tire pressures by a 1/4 of a pound of PSI? I would think maybe by 2 psi increments. Let us know what works for you. I've been running my tires around 6-7 and that seems to be perfect for all around riding.
Thanks for the write up.
2011 Polaris XP 850 X2 LE, Polaris 3500HD Winch, Polaris Deluxe Front Brush Guard, ATV Guru Rear Bumper, Front Lock box, SS312 Wheels and 26" Zilla tires w/slime, Kolpin Fender Flares, Ricochet Ultimate Armor Kit,
2012 Polaris XP 550 EPS, Magnetic Metallic, Polaris 3500HD Winch, Polaris Deluxe Front and Rear Brush Guard, Front Lock box
2011 Polaris Phoenix 200 Red/Black
Old 07-05-2012, 03:43 PM
Maniac's Avatar
Member #3325
I went with the 6 ply because of the size of the tire. I wanted to bump up my size but not affect the center of gravity too much. (Being that I do ride 2 up sometimes.) Also, I wanted to minimize any potential problems with clutching and other mechanical stresses. I havent really been able to tell too much of a difference in 1/4 lb increments. The tread is very soft and flexible at all psi, but I am trying to fine tune the ride without damaging my wheels. I have no experience with radials, so I don't know what to expect.
Old 04-22-2013, 09:25 PM
biz4two's Avatar
Member #208
Arrow
Nice review of the Growlers! So...did you ever find that right psi that gives the best for your type of riding?
How are you still liking the tires?
biz
Took delivery on February 4, 2011
2011 Sportsman 850 Touring EPS -- Mine
2011 Sportsman 550 Touring EPS -- Wifie
Sold 2009 Sportsman XP 850 Sold
Purchase date: May 2009
Sold date: December 2010
Old 04-23-2013, 03:46 AM
Maniac's Avatar
Member #3325
biz
Thanks. I haven't really noticed a big difference in the tire pressure changes. I settled on 5.5 lbs all around. The tire sidewalls are remarkably soft for being a 6 ply and I felt better about having a little extra wheel protection. The handling and traction is unchanged in the pressure range that I tested. (5 - 6.5 lbs.)
I really like these tires! We had a relatively snowy winter here & these tires went through deep snow (12"+) a lot better than my old Carlisle 489's. I haven't been out this spring much yet, but am planning on it in a few weeks.
Up to this point, I only have good things to say about these tires. Something that I have noticed when reading my "Dirt Wheels" magazine... Several of the UTV's that have run and won in the "King of Hammers" and other endurance races were wearing the Growler and Rocker tires. That says something about these Pitbull brand tires...
Old 04-23-2013, 06:17 AM
dueydag's Avatar
Member #2272
Also keep me in touch it's a toss up between rockers and growlers for my 2009 550 xp eps not sure want 8 ply 14 inch rim but the growlers say 9inch and 11 inch ,I don't know if this is an issue I already narrowed my sway bar 1 inch just in case.
2009 550xp eps Camo
Deluxe Front Brushguard, Pitbull, Rockers, STI HD@ Rims, jccapri bushing set, Hand & Thumb warmer, Windshield, 3500LB winch, Kp Gun Boot IV, Warn 60" Snow blade, Power Pivot, Ball Hitch,Front Storage box, Deluxe rear Bumper, Rear rack, Rear Cargo box, Chain saw bracket Custom made, Outboard motor carrier bracket rear custom made. Fold-Up boat carrier side mount custom made, Rubberdown a arm lift kit 2 1/2". . EPI primary Spring Silver 71/155, skid plate protection, RotoPax Fuel tank front, Collett headset, Odyssey battery.
Old 04-23-2013, 07:07 AM
Maniac's Avatar
Member #3325
I can't speak of the tire width on your quad. My Touring has a different suspension and different sway bar. I went with the 25.5" tires. My quad (oem) calls for 8" wide up front and 11" wide in the rear. The Growlers that I got are 8" wide up front and 10" in the rear. It doesn't bother me though. The 11" tires protected the rim a little better, but these tires have a nice wheel protector built into them. I haven't had any issues & feel that it looks better like this.
I was a little hesitant when buying the narrower rear tires. But, I knew that radials were different animals and by increasing the numer of ply's that they handle loads better and safety isn't an issue. (Due to the increase in ply's, I am able to carry even more weight if necessary.)
One thing that I never mentioned about my switch was that my big Sportsman Touring feels MUCH more athletic with these tires. (less Jeep like) The steering / turning with these radials is instant. The tuck and dive of the bias tires is gone. It breeds a lot more confidence if you decide to ride faster. Not to mention that I am able to flick the rear more easily on demand. Before with (bias tires) all of that sway, it took more body english and was unnerving at times.
Old 04-23-2013, 09:10 AM
Member #11270
Good follow up. Thanks for posting your opinion.
Useful Links:
Shop ATV/UTV Tires
Shop ATV/UTV Wheels
Current Promotions
25.5 pitbull growler polaris touring
pit bull atv tire reviews
pitbull atv tire review
pitbull atv tire reviews
pitbull atv tires
pitbull atv tires for sale
pitbull growler atv tire review
pitbull growler atv tires
pitbull growler atv tires for sale
pitbull growler atv tires sale
pitbull growler in mud
pitbull growler tires atv
pitbull growlers for sale
pitdbull growler atv tires too heavy
polaris pitbull tires for sale
Pitbull rockers sportsman_rider ATV Wheels & Tires 5 06-20-2012 12:45 PM
Pitbull Tires Maniac ATV Wheels & Tires 5 06-13-2012 06:26 PM
pitbull rocker tires? chad1926 ATV Wheels & Tires 15 08-12-2011 09:36 AM
Pit bull growler atv tires Juice30 ATV Parts for Sale 3 06-21-2011 11:45 AM
2010 Polaris 850 XP W/ Pitbull Rocker tires in 12" of snow michael1871 ATV Media 17 02-25-2011 06:23 PM
