Tires dry rotted leaking - innner tube ? - Polaris ATV Forum
Old 08-22-2012, 03:06 AM
osbourne's Avatar
Member #29279
Two of my stock tires dry rotted on my 2004 Sportsman 500. The air stays in long enough for my riding needs but the next day they are in need of more air. Was wondering if I can find a mechanic to put an inner tube would the tube do what its supposed to do or will it pop up where the rot is.
Old 08-22-2012, 05:30 AM
Old 08-22-2012, 06:06 AM
bobx2's Avatar
Premium Member Premium Member
Member #14376
You need to just replace the tires if they are that bad. Not worth the effort or the risk to try and put a band-aid on junk tires.
Old 08-22-2012, 06:16 AM
osbourne's Avatar
Member #29279
That's kind of what I was thinking but I was hopeful. Any issues with ride/handling if if I have two new. One in front and one in back?
Old 08-22-2012, 06:38 AM
bobx2's Avatar
Member #14376
As long as they are the same size, and measure the same height, you should be ok. I would search around, ie; craigslist, ebay and try to find a matched set. There are always some good cheap deals to be found. Most people all but give away OEM tires when they upgrade.
Old 08-22-2012, 03:39 PM
skizmo's Avatar
Member #13773
agree to that..I sold my stockers with 10 hrs on them for $25 a tire ($100)...just to get them the hell out of my garage..The guy that came to buy them was so happy..And so was I!!!
2011 550XP CAMO
Old 08-23-2012, 07:46 AM
osbourne's Avatar
Member #29279
Been poking around Craigslist as suggested. My sizes are front 205 80 12 and back are 270 60 12. I know the 12 is rim size. Should I be looking for 25/8/12 and 27/6/12? Not sure if I have to get the exact size to replace them.
Old 05-02-2013, 11:54 PM
GeorgeM's Avatar
Member #35996
I also have an issue here. I just had my tires removed from the stock wheels and they both had inner tubes. I was going to replace the tires due to dry rotting sidewalls and 1 had a slow leak. I'm assuming the wheels would leak without inner tubes so is it okay to use tubes again or is it a good indicator that I should replace the wheels? They have a fair amount of rust but not widespread deep pitting...Thanks.
Old 05-04-2013, 06:08 AM
faawrenchbndr's Avatar
Member #34872
Check with your dealer,......many have near new take off tires cheap.
2012 550 EPS LE, Blue Fire
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
Ricochet skid plates (full kit)
Polaris rear rack extender
Polaris front brush guard
Warn ProVantage 2.5k winch
AmSteel Blue synthetic winch rope
Custom billet hawse fairlead
Denali 60" mid mount plow
Old 05-07-2013, 11:31 AM
biz4two's Avatar
Member #208
Arrow
Never seen sizes like that on an ATV. Hmmm...
^^^ BUMP ^^^
Hope someone can help you here...
biz
Took delivery on February 4, 2011
2011 Sportsman 850 Touring EPS -- Mine
2011 Sportsman 550 Touring EPS -- Wifie
Sold 2009 Sportsman XP 850 Sold
Purchase date: May 2009
Sold date: December 2010
25-8-12 inner tube
25-8-12 tire tube
can i use inner tube ona tire with dry rot
can you put inner tubes in atv tires
can you put tubes in dry rotted tires
dry rot atv tires
dry rot tires inner tube
inner tube in dry rotted tire?
putting a tube in a dry rot tire
putting tubes in dry rotted tires
will a tube fix a dry rotted tire
www.intertubeforfourwheelertires.com
Inner tube? ripp6957 ATV Wheels & Tires 5 08-16-2012 02:31 PM
Oil leaking from vent tube Scooby Polaris Predator 2 08-15-2012 07:04 PM
carb bowl drain tube leaking while reaving ducker1 ATV Repair and Maintenance 3 07-15-2012 05:11 PM
2012 500 ho leaking gas from carb overflow tube dbmachine ATV Repair and Maintenance 7 04-12-2012 02:46 PM
1995 trail boss with dry rotted vent hoses new2polaris ATV New Members 11 05-27-2010 09:09 PM
