Old 03-02-2010, 02:00 PM
dirtdizzy's Avatar
Member #2668
2010 xp 850 ?
will outlaw radial 28x12x14 fit under my 2010 xp without mods? on the rear?
i was told the front should not have any problem on the 9.5.
Old 03-02-2010, 02:49 PM
PawPaw's Avatar
Member #962
They may close to the swaybar being 12 inches wide. You can use a spacer if you want to run them on the stock wheels or buy new wheels. The rear may be the problem not the front's. Just a guess!
Old 03-02-2010, 02:50 PM
850xp4me's Avatar
Member #3058
They should. They re-designed the rear suspension to allow more clearance for wider rear tires on the 2010 model. Guys are getting 12s on the 2009 by bending the sway bar, so with the extra clearance of the 2010, there shouldn't be any problems.
2010 850 xp
2010 polaris xp850 wheels
28 outlaw radial on stock polaris 850 xp
28x12x14
28x12x14 atv tires
28x12x14 mudlite 850xp
28x12x14 radial tires
30 outlaw radial fit 850 xp
30" outlaw radials polaris 850
850 xp outlaw radials
850 xp with radial outlaw
will 28 inch outlaws fit on a 2010 xp 850 eps
will 28x12x14 mudlite xl fit on polaris sportsman 850
2010 scrambler denseleit Polaris Scrambler 1 02-24-2010 07:08 PM
2010 850 Touring .....need a pro. Fasteddie08 Polaris XP 4 02-11-2010 07:11 AM
2010 sportsman 400 sportsman400ho Polaris Sportsman 2 01-03-2010 07:49 AM
2010 550 xp EPS edgexc Polaris XP 2 12-23-2009 04:43 PM
2010 Models? dascrow ATV Purchasing and Price 12 06-30-2009 05:41 PM
