03-04-2010, 06:18 AM
Member #2739
New tire problem
I have an 09 850xp. I just replaced the junk stock tires with Big Horns 26x9x14 and 26x11x14. They rub the sway bars at certain angles. Should I buy the rediculously expensive spacers or should i modify the sway bars? Has anyone tried taking the sway bars completely off? If so, how does it ride afterwards?
 Not until you lose everything are you free to do anything.........
2009 Polaris 850 xp
03-04-2010, 07:20 AM
Member #3058
I bent the rear sway bar using a ratchet strap to fit the Bighorn 2.0s on my 850. It was a pain in the ass, but it works. Do a search - several people have done it. I would recommend this over removing the sway bar or using spacers.
03-04-2010, 11:08 AM
Member #1634
I second what 850xpme wrote ,and i wouldnt recomend taking off the swaybar it gonna feel top heavy and ride diffrent then it does know.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
03-05-2010, 05:18 AM
Member #2739
Well, the strap thing didn't work. With three of us taking turns cranking as hard as we could all we did was bend one side maybe a half inch. For now, I just left the sway bar unhooked and took out the bottom mounts. If anybody else has removed the sway bar, comments would be appreciated on the ride of the bike.
2009 Polaris 850 xp
03-05-2010, 05:35 AM
Member #3058
It took a few times for me to get it bent enough. I let it sit overnight a couple nights. If it's not going to work for you, I would use wheel spacers over removing the bar. Spacers would be the less drastic change of the two.
03-05-2010, 03:14 PM
Member #3440
I have a 2010 850 xp and was thinking of getting those same tires, the Maxxis bighorns. Would i have the same problem or did they change the sway bar as i heard elsewhere.
03-05-2010, 04:51 PM
Member #962
They changed the swaybar to give more clearance and they should fit. Try the search feature, I'm sure someone's done it by now.
03-06-2010, 05:11 AM
Member #3058
No clearance problems on the 2010. Polaris wised up and changed things.
03-06-2010, 03:41 PM
Member #3440
kool, this is what these forums are about... thanks guys!
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
08-28-2010, 01:19 AM
Member #2920
Very interesting that you couldn't get that bent. I was able to do it very quickly with a. 2" truck strap. It bent just like butter.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
are stock xp tires junk, atv tire problems, new atv tire problems, new tire problems, polaris atv, polaris atv ranger tire problems, polaris ranger junk, polaris ranger junk forum, polaris ranger tire forums, polaris ranger tire fourms, polaris ranger tire problems, polaris xp tire junk, ranger atv tires, unhooking sway bar polaris sportsman 800 touring, what tires should i buy for my polaris ranger
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
tire balancing
bakada |
ATV Wheels & Tires |
5 |
02-06-2010 08:17 AM |
tire size
scott09 |
ATV General Discussion |
5 |
01-13-2010 09:15 AM |
Tire help!!!!
jimthescrambler |
1 |
12-01-2009 04:36 PM |
tire inflation
danger ranger |
6 |
11-20-2009 01:03 PM |
tire out of balance?
PoLaRiSnUt |
Polaris Sportsman |
7 |
09-30-2009 11:44 AM |
