Old 03-11-2010, 02:02 PM
850XP too wide after wheel install, suggestions?
I have installed ITP SS112 wheels and ITP TerraCross R/T tires. My problem is that the quad is too wide now for our trails in Wisconsin & Michigan as well as for my own personal preferences with the rear at 5+3 offset.
I see that ITP makes a different offset for the RZR. If I changed over to the SS112 offset 3+5 (part number 1428315404B* for the RZR 4/156) would they stick out less? My second option is to run the SS112 fronts on all 4 wheels (part # 1428313404B) If I go that way what is the largest tire that will fit on that wheel?
3rd option is to go back to stock but I prefer not too. Any suggestions and or ideas? See pictures below. First is with the rear 5+3 offset and the other two are the fronts mounted on the one side.
Old 03-11-2010, 02:54 PM
kling2001's Avatar
Member #3575
Whats your total width ?
Stock 850/550xp Length/Width/Height 83.25" / 211.4 cm, 47.6" / 120.9 cm, 50.75" / 128.9 cm
I found this, hope it helps
2009 Wisconsin Act 85
2009 Wisconsin Act 85 makes the following changes to the statutory definition of an ATV:
o Increases the maximum manufactured width of an ATV to 50 inches.
o Requires that the ATV be designed by the manufacturer to travel on three or more low-pressure
tires.
o Increases the maximum operating pressure for a low-pressure tire to 10 pounds per square inch.
o Eliminates the rim diameter requirement.
The Act also prohibits the operation of an ATV with tires other than low-pressure tires and prohibits
modifications to an ATV that result in its width exceeding 50 inches.
Effective date: December 16, 2009.
http://www.legis.state.wi.us/lc/publ...t085-sb241.pdf
Old 03-11-2010, 03:35 PM
between 54-55 inches now depending on how much air I have in them.
Old 03-11-2010, 03:44 PM
chopper89's Avatar
Member #1634
Are you worried about registering your machine? they go by the stock width. and in all mine miles of trails I have yet to see a warden and I dont think there to concerned about a couple inches. I got the same width as you with mine itp rims and tires. on a 850 xp.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 03-11-2010, 04:38 PM
I have stickers for it already Chooper. I would just like to get it down a few inches. I am planing a trip to SD & another to Utah. I know the gates there are around 52 inches.
Old 03-11-2010, 08:12 PM
BRKCOP's Avatar
Member #2164
MrThor I know this doesn't answer your question, but I just wanted to make a comment regarding the regulations. I would have to say that if there is a warden looking to stop you and measure your width of your machine while out riding, they have way too much time on thier hands.
Not sure where you are thinking about riding in Utah, but if it is in the Moab area, Jeep capital of the world, you will not have any visits from a warden regarding tire size. Haven't run into any gates in this region when I have ridden there either.
2009 Polaris 850XP EPS, Stealth Black, OGIO Bags, ATV GURU Bumpers, more to come. XPOG#0
2009 polaris 850 xp eps wheel bearing
2009 polaris 850 xp eps wheels fit rzr
850 xp bumper
850xp with ss112 wheels
are 25 inch grim reapers smaller than stock rzr tires?
biggest tire on stock 850xp
largest tire for 850 xp
largest tires on stock rzr xp
largest tires size on 850xp
length & width of a 4 wheel atv
polaris 850 xp wheel offset
polaris atv rear wheel offsets
polaris razor s wheel offsets
polaris rzr wheel offset
polaris sportsman wide front tire install
polaris xp tire size and rim offset
sportsman c7 wheels
tallest tire on sportsman 850
what is the biggest size wheel that i can run on a 09 polaris 850 xp
what is the biggest tire that will fit on stock polaris rzr
were to mount the license plate any suggestions Odds-r-even Polaris Sportsman 26 04-09-2010 09:02 AM
Noob here; got an 03 Troy lee. Looking for suggestions rsmith0801 Polaris Predator 3 03-11-2010 04:37 PM
suggestions for my 2009 850 xp realdeal850 ATV Performance Modifications 9 03-06-2010 03:40 AM
Brc nation-wide action alert ATVs Today.net ATV General Discussion 2 02-15-2010 08:15 AM
easy way to install wheel bearings clutchman ATV Repair and Maintenance 10 06-09-2009 08:41 AM
