Aftermarket wheels and tires ?? - Polaris ATV Forum
post #1 of 8 (permalink) Old 11-21-2012, 02:45 AM Thread Starter
Midway97's Avatar
Recently purchased a used Polaris Sportsman 800 x2 4x4 and I'm thinking about changing wheels and tires to dress it up a bit. Questions: Should I stick with the OEM sizes front and rear or go to an all around type size? I hear the aftermarket wheel offsets are slightly different than OEM, is there a safe range to play with and avoid interference? If I decide to go to a larger tire is there a max size recommended, OEM is 25 how large can I go and avoid rubs or binding? Have been reviewing Rocky Mountain ATV site..any MFGs to avoid? Looking for an all around tire/wheel combo I think.
Thanks in advance,
Wayne
Midway97 is offline
post #2 of 8 (permalink) Old 11-21-2012, 05:16 AM
bobx2's Avatar
If you go with a 4+3 off set rim, you won't have any problems using a larger than OEM size tire. I had 26-9-12 fronts and 26-12-12 rears, Maxxis Bighorns on my '07 800 X2. I ride with a guy who is running 27" Bighorns on his '08 700 X2, and he has no clearance problems.
The wheels are ITP Delta steel. Cheap but extremely tough wheels. It is a great combination for a tough, go anywhere setup.
bobx2 is offline
post #3 of 8 (permalink) Old 11-21-2012, 05:57 AM
bgirard420's Avatar
Bob has you on the right track here. I will add to be sure that there are no width restrictions in the areas the you ride. 4+3 offset allow for clearing larger tires but often times pushes the ATV total width just over 50" which is illegal in some areas.
As for the MFG's, bighorns are a crowd favorite as they are a good all around tire. There are so many opinions about tires, it's hard to give a recommendation without knowing exactly what you're looking for (price, size, use...ect).
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #4 of 8 (permalink) Old 11-21-2012, 06:40 AM
Bruce! is offline
post #5 of 8 (permalink) Old 11-21-2012, 07:01 AM
bobx2's Avatar
You are right. I did forget to mention the width. Not something I think much about because there are really no trails around here with that restriction. I think my X2 was right at 50" with that setup, but I won't swear to it. Those tires and wheels are now on my wifes 500, but I don't know how accurate that comparison would be. I do know that it would fit between the wheel wells on my 3/4 ton Chevy.
bobx2 is offline
post #6 of 8 (permalink) Old 11-21-2012, 02:09 PM Thread Starter
Midway97's Avatar
Thumbs up Thanks!!
Thank you folks, great info in short order!!
And also big thanks for the 50 inch heads up, we have those restrictions here and I didn't even think about that when I was doing my initial research.
Midway97 is offline
post #7 of 8 (permalink) Old 12-01-2012, 03:03 PM Thread Starter
Midway97's Avatar
New Shoes!
Thanks for the help and advice guys!! Added a set of STI HD7's wrapped in 26 inch Bighorns, not as radical as most on here but I have to start somewhere right!! Ordered a pair of Guru brushguards today to keep the upgrades coming.
Thanks,
Wayne
Midway97 is offline
post #8 of 8 (permalink) Old 12-01-2012, 03:59 PM
bgirard420's Avatar
Looking good
Rather be riding, instead I'm using Tapatalk
2010 Polaris 500 HO
Ballencing aftermarket wheels & tires 02345ss ATV General Discussion 6 03-27-2012 03:04 AM
spacer vs aftermarket wheels Scrambler2Sportsman ATV Wheels & Tires 0 03-12-2012 12:03 PM
sportsman xp aftermarket wheels chad1926 ATV Wheels & Tires 0 08-16-2011 06:38 PM
stock looking aftermarket wheels task125 Polaris XP 8 01-13-2011 11:22 AM
Aftermarket wheels for 04' 400 sportsman Warbird ATV Wheels & Tires 1 10-26-2009 04:08 AM
