04-05-2010, 02:39 PM
Member #4112
Bigger tires on '09 XP 550
After a year the stock tires are junk and its time to put that tax refund to good use. The question is will 27x11-14 on rear and 27x9-14 front fit? I have heard alot about bending sway bars, which i REALLY don't want to do. Whats the cheapest/best way to make they fit if they don't. Or will the fit with no issues. I am thinking of going with the STI Mud Trax XL in the size i listed. Thanks for any help.
04-05-2010, 02:57 PM
Member #3440
They won't fit. wheel spacers are the quickest and easieast
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
04-06-2010, 03:22 PM
Member #4112
Will it need spacers in the front and back or just the back? All the issues i have been hearing have been about the back rubbing. Also does going to bigger tires have any effect on the warranty?
04-06-2010, 03:33 PM
Member #3440
Spacers for the back. From what i hear they are putting clutch kits in with the bigger tires, yours arent too big though, so not sure. Call your dealer about the warranty, more than likely they wont warrant it.
RIDE ON !!
04-06-2010, 04:05 PM
Member #1414
all depends on the dealer with mud tires,some ignore them and some do not. the only 11" rear tire that will work on the xp without some mod is the zilla.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
04-07-2010, 10:36 AM
Member #3575
I put 27x9x14 on the front, and 27x11x14 on the rear of my 09' 550xp.. I went with these GBC Spartacus ATV Tires
I didnt want to bend the sway bar, so i put these on 1in WHEEL SPACERS -WSP2-M #464 | Twisted ATVs and couldnt be happier.
It only needed spacers for the back, but i put them on all the way around for the tracking, the tires stick out a little from under the fenders but not to much at all
I go looking for mud, but still wanted a good radial tire for trails, and if i go on pavement they wont wear out so soon , and them being 8 ply, they are more puncture resistant, and i go through some pretty serious mud.
I asked my dealer about the larger size, and they gave me a number to call for polaris warranty, and they said the slightly larger tire would not void my warranty, only if its too large and agressive.
04-07-2010, 04:28 PM
Member #1634
I have 27's on mine 850 and they warrentird the steering knuckle no problem like snw629 said its up to the dealer
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
04-08-2010, 03:43 PM
Member #3440
hey Chopper, did you have to put a clutch kit in for those tires, and did you lose any speed or power. I like the extra ground clearance i seen in your album
RIDE ON !!
04-08-2010, 03:56 PM
Member #1634
no clutch kit one size bigger and your ok. I honestly cant say I have had these tires on from the moment I got it they put them on at the dealership.
I was going to put them on when I got home but the guys at the dealership wanted to see them on mine ride so they put them on for free.
All I can tell you I can smoke mine brother on his 800 sportsmen. there 27-14 ITP XTR's . Awsome tire by the way.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
04-10-2010, 05:39 AM
Member #962
 Had to use 1" spacer's in the rear to clear the swaybar but no problem's with these XTR's so far. 27's.
09 550 polaris wheel spacers, 2009 polaris xp550 wheels and tires, 30'' silverbacks on 550 xp, atv forums: polaris xp wheel spacers, bigger tires on polaris 550 xp, biggest mud tires to fit polaris 550 xp, biggest tire for 2006 polaris sportsman 500 ho without a lift kit, biggest tires i can fit on 09 polaris xp 550, biggest tires that will fit a polaris 550 xp, biggest tires you can put on xp 550, largest tires that will fit on a stock sportsman 550, polaris 550 clutch, polaris ranger puncture resistant tires, polaris sportsman xp 550 largest tire size, sportsman 550 with silverbacks, what is the biggest tires you can put on 850 polaris, what is the largest tire that will fit on a 2008 polaris 500, whats the biggest tire i can put on an 05 sportsman 800, whats the biggest tires to go with for xp 550, will bigger tires void polaris atv warranties
