04-25-2010, 12:02 PM
Member #4526
Stock Maxxis Tire Press Predator 500
Newbie.........Glad to be here!
I just bought a 2004 Predator 500 with stock Maxxis Tires. The tires appear to say 36 psi max.........am I reading this right! Thanks to all! Willie
04-25-2010, 01:43 PM
no! thats probably the max PSI when you are trying to get the beads to seat on the rim. its probably somewhere in the range of 5-10psi. ask redneck2725, he should know, as he as basically the same machine
Member #3583
Read closer.
Max pressure to install on wheel. Running pressure is likely around 4-6 psi.
Jerry
2010 Red 850 "T" & '08 700 Camo Grizzly w/ EPS & '07 700 Camo Grizzly w/ EPS
04-25-2010, 03:33 PM
Member #4526
I set them at 8psi.........Thanks for pointing out that's max PSI to set the bead!
04-25-2010, 04:38 PM
8 sounds good!
04-25-2010, 05:00 PM
Member #3177
Chiming in a little late here, but you want between 6-8lbs in the front, and 5-7 in the rear on the stock tires
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
07 polaris predator tire pressure, maxxis predator, polaris outlaw 90 tire pressure, polaris predator 500 05 tire pressure, polaris predator 500 tire pressure, polaris predator 500 tire presure, polaris predator 500 tires, polaris predator 90 tire pressure, polaris predator oem tires, polaris predator recommended tire pressure, polaris predator stock tires, polaris predator tire pressure, polaris predator tires, predator 500 tire pressure, predator 500 tires, tire pressure for polaris predator, tire pressure for polaris predator 500, tire pressure polaris predator, tire pressure predator 500, what kind of tires come on a polaris predator five hundred fourwheeler
