Old 04-29-2010, 06:07 AM
jethrob's Avatar
Member #3471
Will a sportsman 500 handle 27" zillas?
I'm looking to buy tires for my 06 sportsman 500 HO.
I have a heelclicker clutch kit installed on it.
I don't want to lose much power. I dont' care ANYTHING about top end. The machine runs 57 MPH the way it is and could use toned down some.
Looking at either 26" or 27" zillas.
Anyone have advise?
06 Sportsman 500 HO non EBS
06 Honda Recon 220
09 Coolster 125
Old 05-12-2010, 03:30 AM
AI_guy's Avatar
Member #4706
Anyone have advise?
I just put 27 inch Mud Lite's on my 05 SP700, even after moving the tie rod end and adding washers to the lugs, they rub. You may want to stick with 26's. If you get 27's I'd recommend either getting offset wheels or wheel spacers.
Old 05-12-2010, 03:47 AM
SLIDER's Avatar
Member #618
You should be fine with that clutch kit and 27" tires.Like AI guy says,you will need new rims with the right offset or wheel spacers.They will definately rub the strut up front.
06 Predator 500 TLD
07 Sportsman 500 EFI
09 Sportsman 550 XP
26 or 27's on sportsman 500
27 inch tires on a polaris
27 inch zillas
27 on sportsman
27 tires on polaris sportsman 500 ho
27 zillas
27 zillas on sportsman 500 ho
can i put 27 inch tires on a polaris sportsman
how much power do i loose if i put 28 inch mud tires on a 500 sportsman
how tall are 27 inch zillas
mud tires for sportsman 500
polaris 2011 500efi with 27inch tires
polaris 500 ho sportsman 27 zillas
polaris sportsman zilla 27
sportsman 500 mud lites or zillas
sportsman 500 on zillas
sportsman500 run 27 inch zillas
what kind of rims and 30 inch tires do i need for my 2006 polaris sportsman 500 h.o.
will 27 fit on sportsman 500
will a 500 sportsman push 27 tires
2002 Sportsman 700 Twin "No Spark" tarzy ATV Repair and Maintenance 3 09-19-2011 03:02 PM
2004 sportsman 500 ho questions/concerns "newbiee" nicks500HO ATV Repair and Maintenance 11 05-26-2011 01:49 PM
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 4 05-18-2011 03:30 AM
28" Zillas on XP pics mytiburon ATV Wheels & Tires 13 07-07-2010 03:40 PM
95 700 Sportsman intermittent pod failure "HELP" bigtodd ATV Repair and Maintenance 3 02-21-2010 05:35 AM
