05-08-2010, 08:39 PM
Member #4796
what psi to use in mud tires
Hello everyone.I have just had mudlite xtr tires put on and when i checked psi they had been set 13 & 12.I thought that was a bit high so i changed them to 9 & 8.I have no experience with anything but stock tires and am wondering just where the psi should be.Maybe the same as stock? Any help is much appreciated.Thanks.
05-09-2010, 04:21 AM
Member #1414
you do not say what quad they are on? this is my 3rd set of XTR so i have about 3000 miles ride time on them. i like 5 psi front and rear for general trail riding.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
05-09-2010, 04:55 AM
Member #3177
I always went low also, I believe I used 5 in the front and 6 in the rear when I used to ride utility quads
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
05-09-2010, 06:35 AM
Member #3583
5-6 sounds good to me...except in the mud. I kept rolling the tire off the rim until I bumped it up to 10-12.
Jerry
2010 Red 850 "T" & '08 700 Camo Grizzly w/ EPS & '07 700 Camo Grizzly w/ EPS
05-09-2010, 07:33 AM
Member #4796
Thanks people.Ya i forgot to mention it is 850xp.I will probably leave it where it is if the tires are going to start coming off the rims.
05-09-2010, 08:01 AM
Member #962
I've been running 8 psi and when I pull my trailer I go up to 12 psi. These XTR's can take 15 to 18 psi max. On the stock wheels I wouldn't go too low on the air pressure though for everyday riding.
05-09-2010, 08:03 AM
Member #962
Got any pics Honeyman?
05-09-2010, 06:46 PM
Member #4796
Sorry,no pics.I struggle with computers and am happy just to have it start up successfully.
atv mud tire psi, atv tires and rims psi, how much psi should a quad have, ideal atv psi, ideal psi for a mud tire, mud tire psi, mud tire psi forum, mudding tires psi, polaris quad bike psi, psi for mudder tires on street, psi on a atv tire, psi on atv, psi on atv tires, psi, mud tires, atv, tire psi for mud, tire psi for mud tires, what is the psi to use for atv tires, what psi on quads, what psi should mud tires be at, what should mud tires psi be set at
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Pit bull tires!!
ronster_12 |
ATV Wheels & Tires |
23 |
11-08-2010 10:26 AM |
Biggest Tires?
rk082085 |
13 |
01-13-2010 07:42 AM |
Rim and tires
chopper89 |
ATV Parts for Sale |
2 |
12-17-2009 06:39 PM |
What tires?
Crazyhorse |
7 |
12-13-2009 09:40 AM |
Tires?
Ryano |
1 |
09-01-2009 04:20 AM |
