Old 05-09-2010, 09:18 AM
Sharkbait's Avatar
Member #4800
question on tires and wheels
Will 25-9-12 or26-9-12 tires fit on stock 25-8-12 rims?
Old 05-09-2010, 09:34 AM
apltx08's Avatar
Member #2970
Yes, whats important to check for is the RIM size, your 1st # is overall HEIGHT/2nd is tire WIDTH/3rd is RIM size in your case 12" diameter and your width is fine its only an extra 1", 2nd thing to check for is your CLEARANCE, make sure the overall size/height of tire doesn't interfere with fenders, front tie rods or any frame braces inside the fender area...again in your case your practicly the same size.
Old 05-09-2010, 11:18 AM
Sharkbait's Avatar
Member #4800
Thank you very much.This is all still new to me.i want to upgrade to a more aggressive tire,but I wanted to still use my stock rim and I wasn't sure if I could put a 25 or 26-9-12 on a 25-8-12 rim.Again thank you.Also is there any tire you would reccomend?
Old 05-09-2010, 12:08 PM
ajacks87's Avatar
Member #4467
Does anyone know if a 25-10-12 is too wide to fit on the front of a 2010 Sportsman 800 without spacers?
Old 05-09-2010, 02:41 PM
bigd_rock's Avatar
Member #4773
Hey as far a recommending a tire it all depends on what style of riding you do. If you find yourself doing alot of everything including mud and other sticky situations you cant go wrong with the ITP MUD LITE. theyre easy to find and a decent price. Im currently running Carlisle Mud Wolfs and theyre an awsome tire!! great in mud, smooth riding on hard pack, great in rocks and climbing over logs. I went with them instead of the ITP because they are a heavier tire in the side wall and ive had problems putting material through sidewalls. They are a heavy tire but im running an 800 so i wasnt worried about power. Hope this helps
Old 05-09-2010, 02:53 PM
Sharkbait's Avatar
Member #4800
bigd rock
Thanks for info.Was thinking of running mud trax or zilla's...p.s.im on a 500 HO.
Old 05-09-2010, 03:38 PM
chopper89's Avatar
Member #1634
Cool
they will rub the tie rod on stock rims.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 05-09-2010, 04:28 PM
ajacks87's Avatar
Member #4467
Chopper, any suggestions on where to buy spacers for the 2010 model?
Old 05-09-2010, 05:01 PM
chopper89's Avatar
Member #1634
Cool
I found this site you can try rockymountain atvs i have dealed with them in the past and they have good service however couldnt find the right spacer but if you call im sure they have them. Polaris Sportsman – Wheel Spacers | Twisted ATVs
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
Old 05-10-2010, 07:49 PM
bigd_rock's Avatar
Member #4773
In regards to choppers reply. i had stock 26" tires on my stock rims and when i put 27-9-12 on the front of my quad the tires were on the tie-rods. Buying aftermarket rims werent much more than a spacer kit so thats the route i went. Good luck
25-9-12 on rear
can i put a 25-9-12 on a 25-10-12
can i put a 25/9/12 on a 24/9/11 rim
does it matter if you have 25-8-12 tires and you put a 25-9-12 on
polaris tire size 25.9 .12
will a 25 8 12 tire fit on 25 10 12
Fs new 2010 850 xp eps tires & wheels Coastie Joe ATV Parts for Sale 7 10-20-2010 06:44 PM
Info on XP wheels and tires. cc1999 ATV Wheels & Tires 3 08-28-2010 08:46 PM
Polaris tires&Wheels For Sale... MUDDIE49 ATV Parts for Sale 0 04-26-2010 01:49 PM
MUDDIE's new wheels and Tires.... MUDDIE49 ATV Wheels & Tires 16 02-18-2010 05:19 PM
ITP wheels & maxxis tires Tooslo5 ATV Parts for Sale 4 02-14-2010 06:04 PM
