Old 05-09-2010, 05:28 PM
Sharkbait's Avatar
Member #4800
27" zilla's
Question... Are 27" zilla's too big for a sportsman 500 HO? They will be on the stock set of rims with no lift kit or spacer's. Will they fit just fine without any mods and does the 500 have enough power without mods?
Old 05-09-2010, 05:37 PM
chopper89's Avatar
Member #1634
you have enough power but you gonna notice a loss of power ,and it will be hard on the belt ...i would recomend a clutch kit. if you do go that route you could try them and see if its alright with you and if you think you need more torque get a clutch kit. as far as fitting as long as you dont go wider than 9 you will be fine with stock rims and no spacers
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 05-09-2010, 05:46 PM
Sharkbait's Avatar
Member #4800
Thanks again Chopper. Maybe it would be a better idea to go with 26's. Really dont want to make any mods if i dont have to. What you think?
Old 05-09-2010, 07:57 PM
chopper89's Avatar
Member #1634
26 would be an easier route to go. and you can still get a more aggresive tire. one size up isnt a big deal its just with the 500 you will notice a loss of power. and more wear on the belt, it a tough desicion cause the bigger tires do look really sweet. and of course you want to be happy cause you cant take them back if you dont like them.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
Old 09-26-2011, 12:09 PM
mgthrasher's Avatar
Member #19050
I've been running 27" Zillas on mine with no problem. I have noticed a little top end loss, around 5-7 mph. But on the low end not much change. No lift or spacers and on stock time. They have really impressed me on the trails. Will be the next several sets for me.
Old 09-26-2011, 01:51 PM
rodeo1's Avatar
Member #15389
i run 27 zillas on my 450 Kodiak. trick is to run them in low when going through mud and deep water.other wise okay.it will always help if you have a clutch kit , also better air filter k&n or a uni. just my 2 cents.when you go to bigger tires you have to look at weight and size. same weight but bigger tire will be harder to turn.
Old 09-27-2011, 06:51 AM
shore's Avatar
Member #19003
27" zillas are 26" tires. They all run an inch short.
shore's Avatar
Member #19003
Oh and they will barely be heavier than the stockers.
Old 09-27-2011, 07:04 AM
rodeo1's Avatar
Member #15389
wow my 27 zillas measure 27 odd. i know what ya mean though. my bud has 27 inch bear claws and they measure 25 1/2.
2009 sportaman 27 zillas
2010 sportsman 500 zilla
27 zilla
28 zillas on kodiak 450
are 27 tires too big for 500 ho
sportsman 500 ho zillas stock rims
sportsman500 run 27 inch zillas
"URGENT" READ ASAP! OBAMACARE needs to be STOPED! Crazyhorse Around The Garage 12 08-31-2011 09:40 PM
2004 sportsman 500 ho questions/concerns "newbiee" nicks500HO ATV Repair and Maintenance 11 05-26-2011 02:49 PM
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 4 05-18-2011 04:30 AM
I'm thinking "Western States" with Alaska and Hawaii and the rest... Bruce! Western States 8 02-02-2011 05:50 AM
2000 Polaris Trail Blazer "300R" Artic ATV Performance Modifications 0 11-03-2009 08:34 AM
