  #11 (permalink)
Old 05-21-2010, 03:20 AM
SNW629's Avatar
Member #1414
yes i did run my 850 without the dalton kit. the 28" zilla is not that heavy or a true 28" where you have to have the clutch kit. i can never leave my quads stock,for me working on quads adding mods is almost as much fun as riding.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
  #12 (permalink)
Old 05-21-2010, 09:31 AM
xltsks's Avatar
Member #3561
Thanks for the reply SNW629! I'm excited to try out the tires and was hoping that I wouldn't need a clutch kit right away. When the time comes that I decide to get one, I will be going with the Dalton kit. It sounds like a highly researched kit, you should be getting a commission!
  #13 (permalink)
Old 05-25-2010, 09:03 PM
xltsks's Avatar
Member #3561
Can you give me any recommendations for air pressure in the Zillas? I'm hoping to get into some pretty serious mud this weekend and I don't know how much, or how little, pressure to run. Right now I have been running 7psi in the front and 5psi in the rear for running on dry ground. Some people have mentioned rolling their tires off the rim in the mud with 5psi. Any suggestions SNW629? Thanks!
  #14 (permalink)
Old 05-26-2010, 03:31 AM
SNW629's Avatar
Member #1414
i ran 4 psi in mine and never had a problem. the 14" has a stiffer sidewall than the 12" zilla. for me 4psi gives it a ok ride for a mud tire. more and i think it rides a little stiff for my taste.
09 850XP EPS
28 inch maxxis zillas for 850xp
28' zilla kit
30 inch maxxis zillas
30 inch maxxis zillas 850xp
30 zilla pics
30 zilla tire kit
850xp 28 zilla photos
do maxxis zilla run true to size
do maxxis zillas run small
maxxis zilla 30 true measure
maxxis zilla air pressure
maxxis zilla kit
maxxis zilla tire pressure
maxxis zillas on 850 polaris
tire pressure for maxxis zilla
true measurement chart of a 28 maxxis zilla
what tire preasure to rum on zillas
zilla measurement
zilla tire pressure
zilla tire pressurer
maxxis zilla;s model70 ATV Wheels & Tires 10 05-07-2010 03:20 AM
