Old 05-17-2010, 08:50 AM
jdb8025's Avatar
Member #1681
Tire and Wheel Question for 2009 850XP
Just did a ride with a group of snow riders where they absolutely walked all over me. What they were using were Bighorn 12" wide on both front and back. Is it possible to run 12 wide on both front and back on the 2009 850XP using aftermarket wheels? If so what must be done to make it work?
TIA
Old 05-17-2010, 04:55 PM
rugnuts's Avatar
Member #4455
different offset rims and spacers i suspect
heres some info i already assembled so far (mostly about the 2009 models that had the rear clearance issues):
I got this info from various threads from all over, if anything can be confirmed incorrect let me know!!
Plus if you know that the stock sizes for the 2010's are different from the '9s or know the sizes for the regular sportsman line (HO's, Touring's, and X2's) let me know also!!
Due to clearance issues on the '09 XP models, I've combined all important info for future reference.
Stock 2009 Sportsman XP 550/850 tire info:
front rim: 14”x6” / 5-1 offset / 4-156 lug pattern (metric threads)
front tire: 26x8x14 terrathons
ream rim: 14”x8” / 6-2 offset / 4-156 lug pattern (metric threads)
rear tire: 26x10x14 terrathons
Most aftermarket rims (not from a polaris dealer) offer more outward offset, giving you more inside clearance but they will also stick out from your fenders.
There are very limited aftermarket 26"x14" tires 8" and 10" wide. Most are 9" and 11" or 10" and 12". Generally to use aftermarket tires on Stock rims, you will need/want to install 1" wheel spacers. Another option is to bend the tie rod bar inward, away from the tire. Most dealers wont like seeing this done. There are some tires will still fit due to design. (maxxis zilla's dont have much for side lugs so they have been mounted on stock rims). Further more for taller tires, there is a clearance issue up front where there is a "blade" of plastic that hangs down parallel to the tire. It can be removed without concern.
Tire pressures are also a concern. You should check to make sure they are all set to a good pressure (6psi + or - to your liking). Having tires with big pressure differences can affect your ride!
Lugnuts should be torqued to the following specs (per polaris) Steel Rims: 35-55 ftLbs. Alloy Rims: 75-90 ftLbs.
12'' wheel on a 850xp
2009 polaris 850 xp wheel spacer
2009 polaris atv tires after market
2009 polaris stock rims
2009 polaris xp 850 wheels size
2010 polaris sportsman 850xp aftermarket tires and wheels
2010 stock polaris 850 xp rim size
aftermarket tires for polaris 850 xp
atv wheels 2009 850xp
lug nut size for sporsman xp
lug nut spacing for 2009 polais 850
maxxis tires for polaris 850 xp
polaris 850 rim size
polaris 850 tires and rims
polaris 850 xp wheel offset
polaris 850xp lug pattern
polaris xp 850 tire & rim
stock size wheels 850 xp
what is the biggest size wheel that i can run on a 09 polaris 850 xp
what wheel offset do i need for 850 xp
Wheel and Tire pics thread!!!!! cc1999 ATV Wheels & Tires 212 02-05-2012 12:02 AM
Another ITP/MAXXIS 850XP tire question mytiburon ATV Wheels & Tires 4 04-16-2010 05:52 AM
850XP too wide after wheel install, suggestions? Thor ATV Wheels & Tires 5 03-11-2010 09:12 PM
2009 850xp LE production numbers tylermoore Polaris XP 1 02-21-2010 03:47 AM
need help tire and or wheel upgrade on 2000 sportsman tonyy Polaris Scrambler 2 12-23-2009 06:42 PM
