Old 05-20-2010, 12:42 PM
mox052777's Avatar
Member #5001
2010 550xp Wheel/Tire Fitment
New to the site so sorry if this has already been specifically asked and answered?
Just purchased a 2010 550xp and am buying aftermarket tires and wheels for it. The wheels are going to be the MSA 14" Nukes. Question is will 28x10x14 and 28x12x14 ITP Mudlites clear both the front and back, respectively, without the need for spacers and/or any height issues?
Thanks for any and all of your responses.
Old 05-20-2010, 01:17 PM
rugnuts's Avatar
Member #4455
not 100% sure but i think your good to go width wise. (depends on your new rims offset) they will stick out past your fenders though, if thats a problem for ya, fender flares are available.
height may be a problem. there is a plastic "blade" that hangs down above the front tires. it runs parallel to the tire. It doesnt serve a purpose that i know of. others have just been cuttin it off.
could you give me some info on your stock rims. steel/alloy? size? offset? maybe even some pics. im compiling info on XP tires and rims and only have some '09 info.
heres what i got so far (mostly about the 2009 models with the rear clearance issue)...
I got this info from various threads from all over, if anything can be confirmed incorrect let me know!!
Plus if you know that the stock sizes for the 2010's are different from the '9s or know the sizes for the regular sportsman line (HO's, Touring's, and X2's) let me know also!!
Due to clearance issues on the '09 XP models, I've combined all important info for future reference.
Stock 2009 Sportsman XP 550/850 tire info:
front rim: 14”x6” / 5-1 offset / 4-156 lug pattern (metric threads)
front tire: 26x8x14 terrathons
ream rim: 14”x8” / 6-2 offset / 4-156 lug pattern (metric threads)
rear tire: 26x10x14 terrathons
Most aftermarket rims (not from a polaris dealer) offer more outward offset, giving you more inside clearance but they will also stick out from your fenders.
There are very limited aftermarket 26"x14" tires 8" and 10" wide. Most are 9" and 11" or 10" and 12". Generally to use aftermarket tires on Stock rims, you will need/want to install 1" wheel spacers. Another option is to bend the tie rod bar inward, away from the tire. Most dealers wont like seeing this done. There are some tires will still fit due to design. (maxxis zilla's dont have much for side lugs so they have been mounted on stock rims). Further more for taller tires, there is a clearance issue up front where there is a "blade" of plastic that hangs down parallel to the tire. It can be removed without concern.
Tire pressures are also a concern. You should check to make sure they are all set to a good pressure (6psi + or - to your liking). Having tires with big pressure differences can affect your ride!
Lugnuts should be torqued to the following specs (per polaris) Steel Rims: 35-55 ftLbs. Alloy Rims: 75-90 ftLbs.
Old 05-20-2010, 05:28 PM
Moose heated grips and thumb
2009 sportsman 550 xp (tie rods)
2010 550 aftermarket rim problems
2010 polaris rim size
2010 polaris sportsman xp 550 tire size
aftermarket polaris sportsman wheels
older sportsman with xp wheels
polaris 550 sportsman xp wheel offset
polaris 550 xp rim size
polaris aftermarket wheel
polaris sportsman 550 wheels and tires
polaris sportsman xp zilla tires
rear wheel size on a 2010 sportsman 550
rims for polaris sportsman 550 2010
tires for polaris 550xp
what is off set on 2010 polaris rim
what is the bolt pattern on 2010 polaris 550xp
what size stock rim 2010 polaris 550
what size tires fit stock rims for polaris sportsman xp
wheels for polaris sportsman 550 2010
will 2010 polaris 550 wheels fit a 2005 polaris sportsman
2010 550XP with Oven!!! MNForestRider Polaris XP 44 08-19-2011 05:18 AM
How to set idle 2010 550xp?? MUDDIE49 Polaris XP 13 06-07-2010 08:46 PM
Help, is my bearing is bad? 2010 550XP SLxp550 Polaris XP 16 05-22-2010 09:23 AM
Big Horns on 2010 550XP Questions Qman ATV Wheels & Tires 6 03-18-2010 04:32 PM
2010 polaris 550xp browning bcrook97 ATV Purchasing and Price 3 01-20-2010 11:52 AM
