05-25-2010, 07:21 PM
Member #5081
wheel spacers and 27`s
i just got a `05 Sportsman 800 and want to put some 27`s on it...what size wheel spacers am i going to need to run 27`s on the stock aluminum wheels?
05-25-2010, 08:54 PM
Member #2920
Depends on the 27s
Zillias are narrower than other brands.
It's hard to say without a few more details.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
05-26-2010, 04:50 AM
Member #3743
are they 9,10,11,or 12 wide?
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
07-15-2010, 07:34 PM
Member #5386
I'm looking at putting 27X9R12 zillas on the front and 27X11R12 zillas on the rear of my 09 800 touring. Will I need spacers in the front because my stock tires are only 25X8R12. Second question is will I even be able to go to the 27 inch tire because I don't want to rub the fenders?
09 800 Sportsman Touring
Front & Rear brush guard
Rear rack extender
3500 Polaris winch
27" Zilla's
1" Wheel spacers all around
07-17-2010, 07:28 AM
Member #5629
I've found that the stock front wheel has a 4 1/2" backspace. Most of the aftermarket wheels have a 4" backspace. I'm like the kid, what is the width tire you are going to use on the front? If you use 9" tires on the front, it appears to me that you would have to use at least 1" spacer to clear the tierod end. The rear seems to have enough clearance for even 12" wide tires to fit.
Con
1 spacer clear 29.5 inch tires, 27's on a polaris ranger, are tire chains safe to run on the front of a polaris ranger, custom wheel extension for polaris 800 hd, do i need 2.5 wheel spacers for a polaris ranger, how to install polaris wheel spacers?, how to install tire chains on a polaris ranger, how to put chains on front wheel of polaris atv, if you install atv wheel spacer, do you need front and rear, outlaw tire 27 forum, polaris 800 wheels, polaris ranger 3 inch spacers, polaris sportsman 800 spacer, polaris sportsman 800 wheel spacers, polaris wheel extensions, sportsman 500 homemade wheel spacers, sportsman 800 lift and wheel spacers, sportsman spacers front and rear sizes, what size wheel spacer do i need for my polaris, what size wheels spacers do i need to run 27's on a polaris ranger
