Old 05-28-2010, 03:05 PM
slimmer's Avatar
Member #4879
27x10x12 fit on front 2010 500ho
Got a set of mudlights wondering if anyone has mounted these on the stock steel rims? Any problems?
Old 05-28-2010, 04:36 PM
slyder01's Avatar
Member #3440
They will mount on the rims but i believe a guy posted about them on a similar machine and they didnt work without a lift. I'm not sure where the post is... 26's, no problem, but 27's are 2 inches...
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
Old 06-03-2010, 11:45 PM
elmerkit's Avatar
Member #3805
i was thinking of it, well if doesn't fit better upgrade the size of the rim.
Old 06-04-2010, 12:50 AM
Cableguy657's Avatar
Member #3405
my 2006 500 EFI came stock with 26 inch tires, but the fronts are 8 inches wide, i think. you might have some problems with clearance to the tire rod ends, i would find someone to save you the aggravation of mounting them to find that they wont work. although you could mount one and see what you got. at least this will bump it to the top and someone will chime in with the answer.
2011 850 XP EPS
Browning LE
27" XTR's
Atv Guru Cobra series brush guards
Warn XT30
F/R L&R Boxes
G3 60" plow
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
Old 06-04-2010, 05:40 AM
slimmer's Avatar
Member #4879
I'm thinking 10 inch is too widefor these polaris's.I think i will sell them and buy a set of 9 inchers for the front.
Old 06-04-2010, 07:35 AM
Member #3405
how about spacers for the front, ones that are 1/2 inch would be just like going with 9 inch wide tires. Just a thought. i am sure by tonite others will chime in on this subject with there personal experience.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2010 polaris 500 27 mudlights
27x10x12
27x10x12 fit polaris
27x10x12 mudlites
atv 27x10x12 recommended wheel size
atv tires 27x10x12
can i put 27x10x12 avt tires on my 2000 polaris sportsman
can i put 27x10x12 inch tires on a 2008 polaris 500
can you put 9 inch tires on the front of a polaris 500 sportsman
mudlites for stock polaris 500 sportsman spacers
polaris 500ho big tire pics
polaris sportsman 500 9 inch front tires
tires 27x10x12
what size of rims do i need for atv tires 27x10x12
what size wheel spacers for polaris with 27x10x12 on front
will 12 inch wide tires fit on 10 inch wide rims
will 12 inch wide tires fit on atv when stock is 10 inch wide
will 27 fit polaris 500ho
will 27x10x12 fir sportsman 500
will 9 inch wide tires fit on stock 500 sportsman front rim
2010 Sportsman 500HO or 550XP cant deside thepopeis1 ATV Purchasing and Price 16 06-12-2010 09:41 PM
Front rack for a 2010 550 X2 str8aro ATV General Discussion 2 04-08-2010 09:34 PM
2004 Sportsman 500ho front axle bunker471 Polaris Sportsman 3 01-26-2010 04:08 PM
01 Sportsman 500HO KYBruce ATV New Members 3 10-25-2009 04:50 AM
01 sportsman 500ho stcspiderman ATV General Discussion 1 10-20-2009 11:31 AM
