06-02-2010, 05:41 PM
Member #4649
Why aren't Vampire sizes consistent?
I noticed that my front tires didn't look as tall as the back, so I measured them.
The sizes are 26x9.50x12 on front and 26x12x12 on the rear.
The rear tires measure 27.25" but the fronts only measure 25.5". Why is this?
I know that different tire brands can be a little taller or shorter than the tire size that they are listed as. What I don't get is why two different 26" vampires would be 1.75" off.
06-02-2010, 06:23 PM
Crap I thought it was something to do with that Vampire book/movies. I live in the middle of that stuff and I'm sick of hearing about it!
06-02-2010, 07:14 PM
Member #4866
pressure
did u check ur tire pressures to make sure that isnt y
i know it is a obvious thing but just a possibility
2010 850 XP EPS Stealth Black
from dealer
2500lb. winch (with wireless remote)____60" Glacier® II Plow System with extras___Lock & Ride® Front Cargo Box____Rear Rack Extender___Moose hand and throttle warmers
HID Plug and Play Light Kit for 550/850(www.theatvsuperstore.com) lower lights tinted with 20% window tint (still brighter than stock but not blinding bright)
Front & Rear A-Arm Guards XP550/850 2010(www.theatvsuperstore.com)
28" zillas on stock 14" rims(http://www.4wheelparts.com)_____26" stock tires on itp ss212 14" thanks SNW629
Deluxe Front/Rear Brushguard(http://www.superatv.com/)
3 in 1 Polaris atv hitch from (www.theatvsuperstore.com) might i add it was a gift they sent me just for buying some stuff
Galls® 100W Remote Siren (http://www.galls.com/)
lots of lights
motor cycle radio
(still to come Wes Standard(rear seat and storage), dalton clutch kit, 2 inch lift, stealth snorkel kit if they ever make them for the 2010 )
06-03-2010, 07:49 AM
Member #4649
Yeah, 6 psi in both.
06-03-2010, 09:05 AM
Member #4417
what size rims? if your fronts are on 6" wide rims and your rears are 10's that would do it
06-03-2010, 09:34 AM
Member #4649
Same size rims. ITP delta steel 12x7
Seems that they had manufacturing inconsistencies b/c some were made here and some were made in mexico. I've been told that the ones from mexico were made shorter for some reason.
06-03-2010, 10:14 AM
Member #2298
Being that much of a difference in size, I wonder if there is a worry in messing with your 4x4... The rolling radius of the tires is different which would make the front and rear want to turn at slightly different speeds, putting extra stress on your drivetrain.
06-04-2010, 08:32 AM
Member #4649
Looked them up on interco and they list the fronts at 25.8 and the rears at 26.2. They also show both to be mounted on 12x7 rims. My fronts measure pretty close to their specs, but the rears are still a full inch taller than they're supposed to be.
It's also interesting to see that they show the true measurement of the 9.5 width to actually be 9.10. That's a lot closer to 9 than 9.5.
Oh well, guess I'll just run them till they wear out and then get some outlaws.
07-08-2010, 10:55 AM
Member #2147
Kenda Bearclaws are bad about the size differences also. Over an inch difference in the front and rear tire sizes.
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
26 vampire atv, 26x12x12 vampire, 26x12x12 vampire tire, 27 inch vampire tires true od measurement, 27 vampire tire height, 27'' interco vampire true height, are the 26x9.5x12 vampires 26 inches tall or shorter, can i run different size tires on my atv, can you run different size tirs on an atv, interco vampire tire true size, interco vampire true height, interco vampires true size, polaris on 26 vampires, true height of 27 interco vampires, vampire tire forum, vampire tires on front are taller, vampire tires run true to size, vampire tires sizing, vampires tire sizes, whats the real size of 27 tire vampires
