06-27-2010, 08:55 AM
Member #5629
wheel spacers
Being new to this forum, I hope this is in the right place. Here's my question, should I have to use spacers on a '07 sportsman 800 when mounting 27-9x12 and 27-12x12 on the factory wheels using stock suspension? Thanks
06-27-2010, 03:25 PM
06-27-2010, 05:37 PM
Member #5081
you have to use at least a 1" spacer on the front to run the 27`s or tires will rub tie rod ...thats what the dealer told me anyway....same thing for my `05 Sp 800.
06-27-2010, 08:35 PM
Member #5629
Thanks Bruce.
06-28-2010, 02:49 PM
Member #4879
On my 2010 500ho i run 27x10x12 on the front with a 1.5 inch spacer,stock rims. 12 inch wide on the back with no spacer. Probily could have gotten away with 1 inch spacers though.
06-28-2010, 05:35 PM
Member #5629
Ok, after asking the query, I take a look at the front of my bike and what do I see, but a tierod end within 1/2" of the wheel/tire. So I guess that by putting anything but an 8" tire on the front, it would require the 1.5" spacer. I can also see why a spacer wouldn't be needed on the rear. But that the spacer may be needed on the rear to help stabilize the bike if a spacer is used in the front. Any comments?
08-28-2010, 03:27 PM
Member #3834
I put 26x9x12 (front) and 26x12x12 (rear) on my 2007 800 sportsman. I needed 1" spacers for the front to clear the tie rod, and no spacers for the rear with the Polaris aluminum wheels.
07 polaris sportsman 800 wheel spacers 1.5, atv wheel spacers polaris, polaris 1'' wheel spaces, polaris 500 wheel spacers, polaris 800 sportsman wheel spacer, polaris atv wheel spacer review, polaris atv wheel spacers, polaris front wheel spacers, polaris sportsman 500 wheel spacers, polaris sportsman 800 wheel spacers, polaris sportsman front wheel spacer, polaris sportsman wheel spacer, polaris sportsman wheel spacers, polaris wheel spacer 1 vs 2, polaris wheel spacers, sportsman 800 wheel spacers, wheel spacer for polaris sportsman, wheel spacers for polairs atv, wheel spacers for polaris atv, wheel spacers for sportsman 500
