Old 07-06-2010, 10:14 AM
flht38's Avatar
Member #5801
Help with tire size?
I have a 2009 sporstsman 500 H.O. with stock wheels and tires 25X8-12 and 25X10-12. Can I change them to 26X9-12 and 26X11-12 without any modifications? The rears look like they would be ok but the front are only 1/2 to 3/4 of an inch from the tie rod ends right now and look like they would rub? The reason I ask is my local tire dealer has a set of Goodyear rawhide grips new old stock that I could buy for 1/2 of what the correct size would be. Is this a good deal or not? Thanks
Old 07-06-2010, 03:46 PM
Moose heated grips and thumb
Old 07-06-2010, 05:48 PM
chopper89's Avatar
Member #1634
you are correct in being leary about the front because it might rub. I know for a fact you need spacers or aftermarket rims if you go
10 wide on the front. 9 is gona be really really close and might rub you wont know till you put it on. you can always buy 1/2 inch spacer if need be. and the price sounds good. and welcome to the forum
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 07-06-2010, 05:55 PM
fishingdog66's Avatar
Member #4043
If you go to rocky mountain atv you can put your macine in like you are buy them and it will tell you the sizes that will fit.
Old 07-07-2010, 02:29 PM
flht38's Avatar
Member #5801
Thanks for the help guys, I tried rocky mountain and its not really that specific. I was looking for someone that had maybe tried it already because once I buy them they are mine, because they are closeout tires. I really didnt want to add spacers if I didnt have to. Thanks again.
Old 08-21-2011, 07:10 PM
guruerror's Avatar
Member #17443
Two questions about offset (05 Sportsman 700):
1. What is the offset of OEM wheels? I've read that there is no offset...so they'd be 4+4...is this correct? UPDATE: What I read was incorrect. There is a LOT of backspacing on the OEM rims...I haven't measured yet, but I would say they're something like 6+2 on the rear and 4+2 on the front.
2. If a 12x7 wheel has a 4+3 offset would that wheel stick out more or set under the bike more then the OEM rims? UPDATE: The proof was in the pudding...they set out about an inch more on each side.
I've read that the first number is the distance from the mounting center line to the inside wheel edge and that the second number would be from the center line to the outside of the wheel edge. Which would indicate to me that a 4+3 wheel would set further in than an OEM wheel. Is this correct?
Thanks in advance.
...the chrome won't get you home.
CNTRY
25x8 tires to a 26x9 on a stock wheel
atv goodyear widegrip tires
atv tire size changing
atv tire size help
atv tire sizing for polaris
can i put 25x8-12 on a polaris atv
can you change the size of your atv tire
can you change tire size on atv
changing atv tire size
goodyear rawhide grip for polaris
polaris atv tire size
polaris atv tire sizes
polaris atv tires stock size
polaris tire size
polaris tires sizes
polris tires size
replacing atv tire 25x8-12 with 26x9-12
stock polaris tire size
tire size for polaris atv
wheel size polaris 500
Tire size help please paulm235 ATV Wheels & Tires 5 06-08-2010 12:11 PM
tire size help Sharkbait ATV Wheels & Tires 0 05-10-2010 08:25 AM
what size tire smiley ATV Wheels & Tires 3 04-22-2010 04:18 PM
going down in tire size model70 ATV Wheels & Tires 6 03-23-2010 07:09 PM
tire size scott09 ATV General Discussion 5 01-13-2010 10:15 AM
