07-10-2010, 03:17 PM
Member #5899
Need new tires..any suggestions?
I have a '04 700 sportsman with the stock Carlisle Banlands 25-8-12 front and 25-11-12 on the rear. I haven't had much luck with these tires. Its just hole after hole in the sidewalls. I use the ATV for hunting, riding mountain trails and old logging roads, and plowing snow. Any suggestions on a new set of tires?
Thanks.
07-10-2010, 04:10 PM
07-10-2010, 04:24 PM
Member #5629
Welcome. You might want to look at maxxis bighorns or itp xtrs, both good trail tires.
Con
07-10-2010, 10:37 PM
Member #962
 Trail riding with a little mud every now and then these XTR's are pretty good. 6 ply, tough and still ride good too!
07-11-2010, 03:55 AM
Member #2620
ITP Mudlites
95 Magnum 425 4X4
07-11-2010, 05:31 AM
Member #1414
maxxis bighorns, if you hit mud holes more than 10" deep then go with the itp xtr.
2010 550XP EPS, 26" GBC SPARTACUS
09 850XP EPS
RT30 WARN WITH KFI MOUNT
07-26-2010, 11:27 AM
Member #6152
I would go for ITP MUD LITE 6 ply tires my friend got them and they work great.
07-26-2010, 04:17 PM
Member #3476
When you decide what you are after, contact me and I will see what I can do for you price wise. I have the ITPs on my Suzuki Vinson (I know I know) and love them.
Take care,
07-29-2010, 09:51 AM
Member #5375
If I were you I'd look at mud bugs by maxxis. I've owned a LOT of tires gators , bugs , mud lites , xtr's , terra crosses , horns , black waters both slyles , and a crap load more , the names escape me now! An all around tire
#1 is the bugs (imo) #2 horns and #3 xtr's........................MY OPINION AND MY 2 CENTS!! Although check out pit-bull tires I only hear good stuff!! Good luck!
2006 camo brute force 650i modded
07-30-2010, 07:23 AM
Member #5375
The only drawback on the bugs so far is the slow speed riding................it's actually not that bad considering thier similar to a tractor tire tread design. (I want to be as clear as possible ........ they do ride a bit rough at low speeds but nothing bad.The performance , for me , far out weighs thier ride!)
mud lites tires for suzuki vinson, will i need a spacer with maxxis mud bug 25/8/12 on a can am renagade
