Old 07-13-2010, 09:29 PM
JoshH's Avatar
Member #5957
Tire size for stock sportsman 500?
I have a stock suspension and stock rim 2000 Sportsman 500. I am thinking about 27-28'' mud tires, not sure which ones yet. The thing is, there arent many tires that look like they would fit the 11x10 rear rim. Can I just get a tire made for a 12'' wide rim and use it? Any info and tips would be great.
Old 07-13-2010, 10:24 PM
Moose heated grips and thumb
Old 07-14-2010, 07:28 AM
racer37l's Avatar
Member #5629
Welcome. Does your bike have the 4x156mm bolt pattern?
Con
Old 07-14-2010, 12:56 PM
istalvey's Avatar
Member #4997
No Way buddy! You can't put a 12" tire on a 11" rim. A friend of mine just went through this trying to find tires for his 11" rims. They make them but they are hard to find and more expensive because the 11" rim is not common. He did find some Mud Lites but only in a 25" tall tire. Thats probably the biggest you'll find. You best bet especially if you want 27" or 28"s is to buy new wheels also. GL!
2010 Sportsman 800EFI
28" Zillas on 14" SS212 Blacks
RubberDownCustoms 2" Lift
3500lb Polaris Winch
Rear Rack Extender w/Moose cargo box (modified)
Better to have it and not need it, than to need it and not have it.
1998 polaris sportsman 500 tire size
2000 polaris sportsman 500 tire size
2000 polaris sportsman 500 tire sizes
2000 polaris sportsman 500 tires
2000 polaris sportsman 500 wheel size
2000 polaris sportsman tire size
2000 sportsman 500 black rims
2001 polaris sportsman 500 tire size
2004 polaris sportsman 500 wheel size
99 sportsman tire size
polaris 1999 sportsman 500 tire specs
polaris 500 sportsman tire size
polaris 500 sportsman tires
polaris 600 stock tires
size tire on a 1998 sportsman
stock 2008 polaris sportsman 500 efi wheel specification
stock polaris sportsman wheels size
tire size 98 sportsman 500
tire sizes for polaris sportsman 500
Help with tire size? flht38 ATV Wheels & Tires 5 08-21-2011 07:10 PM
2005 Sportsman 800 EFI Stock Tire Change KevGuy ATV Wheels & Tires 4 10-27-2010 07:42 PM
going down in tire size model70 ATV Wheels & Tires 6 03-23-2010 07:09 PM
Newbie Here- Gotta a Sportsman tire size question NH-Rider ATV Wheels & Tires 2 02-25-2010 05:14 PM
tire size scott09 ATV General Discussion 5 01-13-2010 10:15 AM
