07-23-2010, 04:57 PM
Member #6045
Tire/wheel question?
Newbie here with a tire/wheel question........
Will I have any issues with putting ITP SS108 wheels with 26x9x14 fronts, and 26x11x14 rears on a 2010 550XP?
These tires are really close to stock size, but I don`t want any surprises if I buy them.
Also, assuming there will not be any clearance issues, does anybody know if/how much wider this will make the bike?
Thanks......
07-23-2010, 05:24 PM
Member #5386
You will be OK
09 800 Sportsman Touring
Front & Rear brush guard
Rear rack extender
3500 Polaris winch
27" Zilla's
1" Wheel spacers all around
07-23-2010, 06:28 PM
Member #4618
No problems there.
I just replaced my stock CarlisleTerrathons with Maxxis Bighorns, in the 26X9 and 26X11-14s; awesome difference on the trail.
2010 Sportsman 550 EFI
More mods to come.
07-23-2010, 06:36 PM
Member #6045
Thanks guys.......
Phil, I am thinking of trying these tires because I am going to put a bunch of miles on this bike running on sand based roads with a lot of rocky areas. Do you think the Bighorns will hold up well? I have read that they are pretty tough.
Also, do yours ride as smooth as the factory tires?
07-23-2010, 07:19 PM
Member #4618
Originally Posted by Big Country
Thanks guys.......
Just as smooth on the hard trails. I don't do any blacktop riding but I would say they would be as, or nearly as, smooth as the originals. All the reviews say the Bighorns are "bullet proof". After handling them and riding a bit, I believe it. They are definitely a MUCH tougher tire. Mine are the original version, not the Bighorn 2s. The 2s are a lighter version, as I understand it.
Your riding surfaces, as you mentioned, are a perfect fit for the Bighorns.
I'm sure there are other tires that will do the job - but I do like the Bighorns. Can't wait to see how they will do in the snow and on the ice.
More mods to come.
+wider tire problems, 28" zillas on stock 800 sportsman?, atv tire/wheel questions, can i put a wider tire on stock atv rim, can you put a wider tire on a fourwheeler, can you put big tires on stock atv wheels, can you put wider tires on atv, polaris wide tires all around, polarisatvforum, problems with putting wider tire on atv, problems with wider wheels, putting a tire on atv rim, putting big tires on a atv, wider tire on stock rim, wider tires problems
