07-31-2010, 03:00 PM
Member #6251
Will 26x10x12 fit up front?
I have a 2008 sportsman 500 efi H.O and want to get some mud lite tires. My stock size is 26x8x12 front and 26x11x12 back. I found a great deal on a set of mudlites but the fronts would have to go to 26x10x12. Is that a problem going 2 inches wider up front? I have stock suspension and will keep it that way. The backs are 26x12x12 which will be fine.
07-31-2010, 06:06 PM
Member #5629
Welcome. Are you planning to use your stock wheels? I thought about the same thing, and after looking and measuring, found that if I used the stock steel wheels on the front I would have to use at least 1" spacers. I went with aftermarket wheels using 9" wide tires.
Con
07-31-2010, 06:40 PM
Member #6251
Yes I would use the stock wheels. They are the factory aluminum rims that came with the machine.
08-01-2010, 04:12 AM
Member #5629
OK. I don't know the backspace of the aluminium rims. If you look at the space between the stock tire and the tierod end, that should give you an idea of what you'll have to do.
Con
08-01-2010, 07:57 AM
Member #6251
Will do, thanks!
10 inch wide front tires atv polaris, 26x10x12, 26x10x12 atv tires, 26x10x12 front pictures, 26x10x12 tires on front of sportsman, 26x11x12 used tires, 26x8x12 atv tires, 26x8x12 polaris tires, atv tires 26x10x12, can i put a 26x10x12 tire on a polaris 800 sportsman, can you put a 26x10x12 on the front, max tire size for 2008 polaris sportsman 500 efi, mudlites for stock polaris 500 sportsman, polaris sportsman 26x10x12, polaris sportsman front tire 26x10x12 fit, should i upgrade to a 26 tire from a 25 on my atv?, used 26x8x12 tires, wider front tires on 500 efi polaris, will a spartacus 26x10x12 tire fit on stock polaris wheel, will wider tires fit on a polaris sportman?
