Old 08-01-2010, 06:18 PM
NickS's Avatar
Member #5482
How much bigger before new clutch is needed?
I have an '05 Sportsman 400 4x4. I'm looking at getting some new wheels and tires. Factory is 25x8x12 up front and 25x11x12 in the back. I'm thinking about 26 inch tall tires at least and either 12" or 14" rims. Is this going to put much more strain on the clutch. How big is too big on a 400 before I need to start looking at getting a new clutch. I just want to go a little bigger without having to alter anything else on the ATV.
Old 08-03-2010, 07:14 PM
NickS's Avatar
Member #5482
No help?
Old 08-03-2010, 07:20 PM
The Kid's Avatar
Member #3743
26's will be fine 27's maybe 28's no no
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 08-04-2010, 05:03 AM
phil's Avatar
Member #4618
Just as a note - I replaced the stock tires on my '10 550 EFI (they were:26-8 and 26-10 14s) went to Bighorns 26-9 and 26-11 14s originals (not the Bighorn 2); Now these tires are nearly 1" taller than the stocks (regardless of the number "26") and wider and heavier. I really like them a lot BUT I do notice (feel) the difference in performance. It is just a bit sluggish (and I mean a bit) not sure if it bothers me enough to get into a new clutch. Top end also suffers a bit but I don't drive at 60 very often.
2010 Sportsman 550 EFI
More mods to come.
Old 08-04-2010, 06:19 AM
racer37l's Avatar
Member #5629
tire size vs clutch
I think that the Kid is right, 26's will be fine. The only thing that might change that is how you use your bike (mud, sand, trails, rocks, hauling). If you still have any concern about the clutch, then contact some of the clutch manufacturers to see what they say. Just my $.02
Con
Old 08-04-2010, 06:36 AM
bfbill650i's Avatar
Member #5375
26" tires you should be ok. But anytime you upgrade you tires for bigger and heavier not to mention the load put on your engine with the impoved traction. A clutch kit would be a good addition. The machine (usually is) is designed to work best with the traction given , when we alter it by adding tires that have better performance we should add a clutch kit to offset what we have done or even better add to the "stock" setting.
With that being said. Most if not all quads will turn a size bigger (tire) with no trouble. So real world 26" you should be good. 27"s maybe a kit but you could get away with no kit depending on the tire , to be safe we should use a kit.28"s+ a kit.
2006 camo brute force 650i modded
Old 08-04-2010, 06:08 PM
NickS's Avatar
Member #5482
OK, thanks. I think I should be ok it seems. Definitely not going bigger than 26" tall. Dont want to put too much strain on a 400cc.
Old 08-16-2010, 07:28 PM
NickS's Avatar
Member #5482
Also, what about the wheels size, is it going to make much difference going to a 14" wheel and 26" tire from what I have stock. I'm just stuck on the wheels now. I know that i'm not going bigger than 26" on the tires, but I'm not sure if I want to stick with the 12" ITP's or go to 14" ones. I just can't decide. Wondering if the bigger wheel would put too much stress on the clutch, because i'm not interested in replacing it right now at all.
Old 08-24-2010, 09:56 PM
PolarMud's Avatar
Member #628
26"s should be okay on your 400. However, one thing to consider is the overall weight of your wheel/tire package. For example a 26" Mudlite XTR is about 11 to 14 lbs heavier each than a 27" Maxxis Zilla. Believe me weight can be an issue. My XTRs hurt the power on my 500 right much due to the weight of the tires. I'm in the process of putting a clutch kit on it. I had an 04 400 Sportsman and I must say that you don't want to get too carried away with a heavy aggressive tire on it cause that 425cc engine is not the most powerful mill in the world. Its a very solid engine, but its just not the kind of engine thats gonna turn some big ole meats in a powerful efficient manner.
06 Sportsman 500efi LE. 26" Big Horns
09 Mossy Oak RZR w/ 26" Bajacross, Big Gun exhaust
10 Can Am Renegade 800R Muzzy pipe, Dobeck, Precision Steering Stabilizer and anti vibe mounts, Grim Reapers, Twin Air, graphics kit
Old 08-25-2010, 10:15 AM
NickS's Avatar
Member #5482
Thanks for the info, hell I may just keep 25" tires in there and go a little wider in the front. Still not sure on going with 12" or 14" wheels. I need to search the weight of some of the tires. I'm wondering what the difference in weight would be between the stock setup I have now and maybe a 12" or 14" wheel with a 26" maxxis tire or another light aggressive tire.
27 inch tires canam renegade 800
28 inch msxxis zillas on a stock rzr
can i put 27 inch tires on a polaris rzr 800
how big of tire polaris 800 withouth changing clutch
how big of tires before upgrading clutch
how tall are 27 inch maxxis zillas
i want to run 28 inch maxxis zillas on stock rzr
is it okay to put 27 inch tire on polaris rzr
kawasaki 650 brute force clutch kit with 27 inch tires
max tire size for polaris scrambler 400
maxxis bighorns on stock brute force
polaris 800 big tires
polaris rzr fit bigger tires
polaris scrambler 400 use 12 rims
rzr 26 tires with 14 wheels do you need a clutch kit
rzr s factory tire wheel size
stock rzr bigger tires
what clutch kit to get for heavy tires on rzr
what size tires will a 500 turn with clutch kit?
will 28 inch maxxis zillas fit on a stock polaris
bigger plowerplant into a scrambler . . . mustange70 ATV General Discussion 52 07-06-2011 11:42 PM
Wanting to go bigger nickdolin ATV General Discussion 8 06-28-2010 01:10 PM
Bigger tires on '09 XP 550 cwcooper85 ATV Wheels & Tires 17 04-22-2010 08:10 PM
bigger tires n2mudn ATV New Members 8 01-27-2010 05:55 AM
Bigger Tires Jamieg ATV Wheels & Tires 1 10-01-2009 06:32 PM
