Old 08-10-2010, 12:44 PM
XP wheel offset question
I blew my rear wheel on my last ride. I have been searching for a used one but have not had any luck & can not justify the cost of a new OEM vs aftermarket.
Who makes a wheel that's offset is closest to the factory one? I have has the ITP prior but felt the rears were way to wide at 52+ inches with ITP TerraCross tires and sold them.
Also what if I just use the same front offset on all 4 wheels? Can it be done with the 2 different tire sizes? That should at least give the quad the same width all the way around like stock.
Old 08-12-2010, 09:25 AM
When all else fails get it fixed!
Old 08-12-2010, 01:17 PM
Smoothbassman's Avatar
Member #2920
That's a pretty nice repair.
How to you bust the wheel in the 1st place?
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 08-12-2010, 05:16 PM
Going through a water hole at higher speeds. I guess a rock got in there and when the shock compressed BAM I was done.
Old 08-17-2010, 05:13 AM
archer's Avatar
Member #6015
Here are the OEM tire/wheel specs. Don't think any aftermarket wheels will have the same offset.
Front OEM Wheels and tires
Weight = 30.25 Lbs
Size = 14" X 6"
Offset = 5/1
Rear OEM Wheels and Tires
Weight = 35.7 Lbs
Size = 14" x 8"
Offset = 7/1
Actually measured tire Heights.
OEM tires
Front 26/8/14 actual measured height = 25"
Rear 26/10/14 actual measured height = 25"
2010 Sportsman 850XP EPS, 3500 Polaris winch synthetic cable and remote, front and rear brush guards, 5 HID lights, lock and ride rear box, Bighorn 26" tires on stock rims. Hand and thumb warmers.
Brute Force AMR 840 13.1-1, X4 Cams, Muzzy Pro, over-sized 39MM carbs, plus 1.5 mm over size valves, Big Kev performance full race port, JH machine clutch, programmable dynatek, Boss Noss wet nitrous system.
Old 08-17-2010, 06:15 AM
Thanks for the info! I have been in contact with ITP asking the question will they be making a wheel specially for the XP since the current offset is way too wide trails that have the 50 inch gates but they answered no not at this time. I wonder if there are any companies that have a less offset then ITP?
Old 08-17-2010, 07:03 AM
archer's Avatar
Member #6015
Polaris does have another wheel that fits correctly it's called, Vision wheels. Not sure who makes them. Problem with ITP's and others they don't make the 1" outside offset. Even 5/2's are more like 4/3's. Since this machine is already very wide anything over the 1" outside offset puts it well over 50" wide.
Old 08-17-2010, 07:11 AM
Yes with the ITP wheel & TerraCross R/T tires I was at 54 inches in the rear. I was getting sick of eating mud while everyone else was clean. Thats why I went back to stock.
Old 08-18-2010, 07:52 PM
QuadMan's Avatar
Member #5965
I agree Thor. It gets wide with the aftermarket wheels on the XP. But on my SP800 it is fine. Too bad ITP does not make proper wheels for the XP.
2008 Sportsman 800. Stealth black. HIDS and Ricochet Skid Plates.
2009 Sportsman 850XP. HIDS, Wes Lock and Ride box, 3 in 1 ATV hitch and Ricochet Skid Plates from www.TheATVSuperStore.com
Old 01-28-2012, 08:16 AM
kirk611's Avatar
Member #22181
Black Diamonds on OEM wheels
Hey Thor, Is it possible that the Black Diamond tires you have on the C7 wheels would fit on the Polaris stock wheels? Maybe then the outside offset would be less keeping over-all width down.. I have a set of the Black Diamonds and I am considering giving it a try on my 2012 850 touring.. 26x9x14 front, 26x11x14 rear. I'm thinking they should fit and would hopefully not create any rub issues..
2010 sportsman 850 xp wheel fitment
2012 polaris sportsman 850 factory wheel size
2012 polaris sportsman wheel backspacing
850 xp wheel offset
atv wheel offsets
oem polaris wheel offset
offset atv rims
polaris 14 wheel offset
polaris 850 xp rim offset
polaris atv wheel specs
polaris factory wheel offset
polaris sportsman 850 xp wheel offset
polaris sportsman wheel offset
polaris sportsman xp wheel offset
polaris xp itp rim offset
polars rims size
sportsman 850 xp oem wheels
what is offset of xp wheels
what is polaris sportsman 850xp factory wheel offset
Tire/wheel question? Big Country ATV Wheels & Tires 4 07-23-2010 07:19 PM
xp550 wheel and spacer question sharris806 ATV Wheels & Tires 3 07-22-2010 11:59 AM
SuperATV's Sportsman Offset A-Arms Super ATV Polaris Sportsman 2 06-28-2010 10:06 AM
Tire and Wheel Question for 2009 850XP jdb8025 ATV Wheels & Tires 1 05-17-2010 04:55 PM
offset on wheels n2mudn ATV New Members 2 01-03-2010 09:57 AM
