  #11 (permalink)
Old 11-23-2010, 01:54 AM
cwlongshot's Avatar
I have thought much about the same topic. I won't go to 14's because of the stiffer ride. I too put many miles on in a days riding and ride quality is a top priority. The one thing I WILL have is a Radial tire. Now if your riding short distances a std bias tire may fit you perfectly as your saddle time is far less. also sporty riding where your on off and standing for periods of time the ride quality isn't as much of a concern.
Also width, I don't want mine wider either, but would like a alum rim for weight savings. Nothing out there!!!
I found a plethora of info on UTube! There are a couple guys posting videos on different tires. it FAR better than a snap shot in a catalogue. They do give there opinions of the tires, but you can see what they ride in and how they ride in some. I found it very helpful in choosing or at the very least narrowing the options.
If I was buying today, the GBC Spartacus or the Maxxis Big Horn with be my choices. Just remember the BigHorns run a bit larger than others of same size.
  #12 (permalink)
Old 11-23-2010, 06:28 PM
nickster's Avatar
Member #7042
I ended up just running the stock tires and rims for the year but will be changing over the winter to something else. I have found what I'm looking for at my Polaris dealer. The Razr or Ranger? or one of the two seaters come with 12" alum wheels in a 4+2 front and a 5+3 rear. The front's and inch narrower that the 5+2 on my stock 500 and I don't know if that's a problem or not. Anybody know? It definitely will not widen the stance and I will probably be using a stock size tire anyway. I think it comes in black spokes and a couple styles in brushed aluminum. I just haven't gotten around or ordering them yet. I pretty much avoid the mud so a dry surface tire will be what I'm looking for. Any suggestions for the tire? Thanks.
Nick
2009 polaris sportsman 500 ho rim widths
2009 polaris sportsman 500 ho wheel
5 2 atv wheel offset meaning
are the 10'' rims on the 2001 polaris sportsman ride better than 12 rims
best aftermarket size tire for 500 polaris sportsman
best rims and tires for polaris sportsman 500 ho
itp wheels for a polaris sportsman 500 2 5 offset
polaris 500 wheel offset
polaris sportsman 400 ho wheel size
polaris sportsman 500 ho wheels
polaris sportsman 500 wheel offset
polaris sportsman 800 aftermarket wheel offset
polaris sportsman wheels 5 2
what offset do i need for a 2009 polaris sportsman
what size the rims on a polaris 500 ho
wheels for polaris sportsman 500
wheels with stock offset polaris sportsman 500
will 26 tires fit on stock polaris sportsman 500 rims
will rzr wheels fit a 500 sportsman
will stock xp wheels fit on 2009 sportsman 500 ho
Trad me 09 850xp wheels for My 2010 14inch aluminum wheels Quad Master ATV Wheels & Tires 1 09-05-2010 08:26 PM
Info on XP wheels and tires. cc1999 ATV Wheels & Tires 3 08-28-2010 07:46 PM
2010 550xp Wheel/Tire Fitment mox052777 ATV Wheels & Tires 2 05-20-2010 04:28 PM
Info about Sportsman XP Recalls? Need info for an engineering project! beretta390 Polaris XP 3 05-18-2010 06:11 PM
fuel pump fitment defiance666 ATV Repair and Maintenance 0 05-02-2010 11:51 AM
