99 sport project restoration fs/ft
well what i have forsale or will even trade for something cool is a 1999 400 sport 2wd here some info on it:the bike was stripped down to nothing the frame was sandblasted so wasnt the a-arms and swing arm the frame was then sprayed with ppg dodgeviper red and the a- arms and swing arm was sprayed grafite gray and reassembled with new bushings ans bearings and seals, the motor has a new crank,rod,counter bal,waterpump,bearings and seals the topend still needs finished(piston and rings) the trans has also been rebuilt with new bearings seals,chain and had the reverse mod done to it also the motor and trans are in the frame (motor with new hpd mounts) the swing arm is also on the frame as are the a-arms,struts,axel,new chain and sprockets(13/30 with a d.i.d chain)i put preditor hubs on the rear and have black beadlocks (no tires yet)and black dougless rims for the fron(no tires yet)the exhaust is a hpd trailpipe with a dg silencer the clutch has a hpd aggrssive kit in it also with the hpd buttons in the sec.and new belt wraped up with a high flow cover and a 38mm tmx flat slide carb and carbon fiber v-force reeds,we,ll you get the idea it has been a winter project i,ve been workin on to keep busy and is allmost done the only thing it needs are piston n rings,tires,and plastic and you,ll have a new machinethere is a ton more that i have not listed and can go on fore ever if you are intrested shoot me an e-mail or give ma a buz at (440)536-4826
