Go Back   Polaris ATV Forum > Polaris ATV Classifieds > ATVs For Sale
ATVs For Sale Looking to buy or sell your ATV, this is the place for you!
Old 12-10-2011, 04:13 PM
michaelbell85's Avatar
Member #5587
1999 polaris scrambler 400 4x4
Here ive got my polaris scrambler 400 less than 20 hours on it. Engine have some port work done,12:1 hot eat top,reed spacer,vforce delta reeds,Hpd exhaust with repackable silencer,39mm pwk carb,Uni filter,Stiffer front clutch spring,3" front wheel spacers,tranny fluid just changed. Now for the bad quad doensnt idle right needs carb tuned,Fan is hard wired to switch where choke used to be,Seat has to be screwed in to hold needs the spring assembly on seat also needs brake pads, I took a old tranny cable and made a choke line threw plastic for carb,rear sprocket hub needs replaced that holds rear sprocket on. Has brand new winch oring chain and used snow plow with all mount. Like new swamp lite tires. The starter went out of it and i have to pull start. I have to wd-40 to get started. Quad runs good when running and after you start one pull on rope starts it.Pull rope doesnt recoil all the way.Id like $1500 with plow or $1300 without winch and plowThis thing looks a little rough buts runs like hell when running right. I just want a new quad and dont want to work on it any more.Good little quad for someone handy message me if you have any questions. Will part out if i cant sell whole quad.Located in divernon Illinois.
Old 12-11-2011, 04:07 PM
poposcrammy's Avatar
Member #20152
i would give 1200 with winch and plow
1996 POLARIS SCRAMBLER 400
.025 ovebore wiseco
fmf grnarly head pipe stock silencer
25in swamp foxes
12 vision buckshot wheels
purple polaris sport seat to match shocks
v force carbon fiber reeds
reed spacer kit
uni airfilter
COMING SOON
Purple polaris sport hood
aftermarket silencer from hpd-inc.com
cluctch kit also from them
Old 12-14-2011, 06:06 PM
Member #20152
an you get some more pics of it wen you have time
.025 ovebore wiseco
25in swamp foxes
reed spacer kit
uni airfilter
COMING SOON
Old 12-14-2011, 10:04 PM
Member #5587
what do you want pics of
Old 12-15-2011, 07:16 AM
Member #20152
everything and take the seat of and do pics of carb and filter and all that stuff i u can
.025 ovebore wiseco
25in swamp foxes
reed spacer kit
uni airfilter
COMING SOON
Old 12-15-2011, 09:24 AM
Member #5587
pending sale
Old 12-31-2011, 04:20 PM
snakeman's Avatar
Member #21820
If you still have this I would be interested in the plow and winch. Thanks
1999 polaris 400 4x4
1999 polaris 400 sport
1999 polaris sport 400
1999 srambler
99 polaris scrambler 4x4
divernon il
pictures of 1999 polaris scrambler 400 4x4
polaris parts pull start
polaris scrambler 400 4x4 stock sprocket size
polaris scrambler 400 plow
polaris scrambler wheel spacers forum
polaris scrambler winch mount
purple polaris scrambler 400
scrambler 400
swamp foxes on polaris scrambler
1999 Polaris scrambler 500 c_studt ATV Repair and Maintenance 8 07-05-2011 09:02 PM
polaris scrambler 500 4x4 1999 yr kevjams ATV Wheels & Tires 0 03-26-2011 07:40 PM
1999 polaris Scrambler 400 4x4 Problems Focker Polaris Scrambler 6 05-17-2010 06:56 PM
1999 polaris scrambler 500 RODUDE ATV Repair and Maintenance 5 04-09-2010 07:33 PM
1999 Polaris 400 4x4 Scrambler Jesters101 ATV Repair and Maintenance 1 09-03-2009 05:51 AM
